Main > Main Forum
Question about button sizes
Pages: << < (2/2)
u_rebelscum:
IIRC:
The u360 without a restrictor under a full 3/4" panel needs a bigger hole to hit the full range.  A super, competition, p360, and atari/midway/happ 49-way are the same.
Routing decreases the needed hole size for full range of course.  Getting the u360 with restrictor plates does the same.
miles2912:
I just drilled a hole in a scrap piece of MDF and checked travel.  1.25" worked for me.
Don
ArtsNFartsNCrafts:
I know this is an old thread, but my question is within the topic at hand, so why not?
I have a magstik plus, which has a pretty short throw, and was wondering if anyone knew what size i needed to drill the joystick hole.  right now i'm using the standard bat top.  I may switch to a balltop..
leapinlew:
--- Quote from: ArtsNFartsNCrafts on November 13, 2007, 07:47:51 pm ---I know this is an old thread, but my question is within the topic at hand, so why not?
I still drilled a 1.25" hole. You'll need a hole that size when you decide to replace the magstik+ with a better joystick.
 ;) I kid! I kid!
ArtsNFartsNCrafts:
hahaha.  It works for me, and I switch between 4 and 8 way enough to justify using one....i suuuuck if I play 4-way games without restriction (which might suggest that I plain suuuuck regardless, but oh well).
Pages: << < (2/2)
Go to full version
