Main > Everything Else
Easy Ethernet in any Room!
<< < (2/6) > >>
saint:
We use a similar device by Linksys that runs about $80. Once configured you don't need a particular operating system - the configuration is just to encrypt them.
2600:
--- Quote from: ChadTower on June 06, 2007, 09:48:18 am ---
I wonder how all that chatter would affect things like power supplies in other devices.
It's at a high enough frequency that it gets filtered out pretty easily.  It's also why you can't run them through surge protectors, etc as it will filter the signal out.
As for the setup, I imagine it would be pretty simple and one may already exist for a tool that runs on other OS's to configure these.  Just sniff the ethernet data and send the same thing.
ChadTower:
Would that conflict with the telephone adapters that use the same method?
2600:
I don't know about 10 years, but it has been around a while. What's new is that they release a new version that get's decent real speed.
Chad,
Which telephone adapters are you talking about so I'm on the same page?
On a related note, compatibility with other adapters are up to the device and which chip it uses, especially compliance with the older specification.  Some aren't as forgiving.
ChadTower:
Eh, don't bother looking into it.  I remember a few years ago before I learned to run wires, I was looking into some similar devices that would allow you to use your house electrical wiring to add phone outlets.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
