Main > Everything Else
Easy Ethernet in any Room!
patrickl:
--- Quote from: ChadTower on June 06, 2007, 05:51:49 pm ---Actually, I could have a use for usb over AC lines. I keep my main PC in the basement and often it's too cold down there for a printer to function reasonably.
You could also use a USB printserver (I bought one for $30 or something and it worked perfectly). You'd need a network connection going from your basement to the printer then though.
ChadTower:
There are already network connections in most of those rooms... adding another would be a nonissue if it were a room that doesn't have one yet. I'll look into the USB printserver issue. Thanks!
Navigation
[0] Message Index
[*] Previous page
Go to full version
