Author Topic: wico balltop removal  (Read 1051 times)
fdm
  • Last login:December 26, 2008, 04:18:52 pm
« on: May 28, 2007, 01:32:18 pm »
Before I destory the joystick handles I have, I figured I would ask :) Is it possible to remove the balltops from a Wico joystick? I have 2 4" shafts with light blue tops and 2 3.5" shafts with regular blue tops. I want to use the regular blue tops but the 3.5" shafts are too short to allow me to mount the sticks from beneath the CP. So I want to switch them to the 4" shafts.
TIA,
Frank
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: wico balltop removal
« Reply #1 on: May 28, 2007, 01:59:04 pm »
Remove the "E" clip at the bottom, then slide the shaft up and out. Make sure to keep track of which way the parts go, so you don't put am back in upside-down.
NO MORE!!
fdm
« Reply #2 on: May 28, 2007, 02:07:04 pm »
Thanks for the quick reply. I know how to remove the shaft, I was wondering if I could remove the actual ball from the shaft. If I can't I guess my only solution is to mount the joysticks from the top sine the 3.5" shaft will not be long enough if I mount it from the bottom.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #3 on: May 28, 2007, 03:16:09 pm »
The balls are permanently attached.
fdm
« Reply #4 on: May 28, 2007, 07:32:41 pm »
Thanks, that's what it looked like. Just wanted to be sure.
RayB
  • There's my post
    • RayB.com
« Reply #5 on: May 30, 2007, 10:08:03 am »
Sounds like you need the "long" shafts.  (Wico's came in different heights)
NO MORE!!
