Arcade Collecting > Restorations & repair
ROBOTRON cabaret / mini
SirPeale:
Naw, man; that's hella sweet. I'm envious. At least you have a bezel.
CheffoJeffo:
Looks good, RayB!
Once again you take home a project that makes me regret not being at the auction.
ArtMAME:
--- Quote from: RayB on May 28, 2007, 10:47:16 am ---I guess what I'm wondering is, did Williams mount their joysticks so that the bolts went through the top of the CP, like most companies did, or was this plate so that there were no carriage bolt heads on the CP?
Like I said, Im not familiar with Williams cabs, so PEALE, what may seem obvious is not.
The mounting plates are just there to hold the dust washer inside. The actual joystick mounting is done with bolts and T-nuts embedded into the wood. Check out the pics:
http://forum.arcadecontrols.com/index.php?topic=63639.msg634847#msg634847
The 4 outer holes (small) hold the plate onto the wood with wood screws. The 4 inner holes (larger) hold the T-nuts and the joystick bolts enter from the underside of the CP to meet the T-nuts on top.
SirPeale:
--- Quote from: ArtMAME on May 29, 2007, 10:30:29 am ---The mounting plates are just there to hold the dust washer inside. The actual joystick mounting is done with bolts and T-nuts embedded into the wood.
Ah! I did the same thing with the Super High Impact conversion I got. Except I used plexi instead of a metal plate.
DARRYLICSHON:
good luck, i have been looking for a robotron cab to restore also.Darrylicshon
Navigation
[0] Message Index
[*] Previous page
Go to full version
