Author Topic: Keyboard encoder for a Jukebox and power source for lit buttons  (Read 1485 times)
MPTech
  • Last login:December 31, 2023, 06:13:37 pm
  • UltimateArcade completed!
Can anyone recommend a simple encoder for a Jukebox that will only use about 20 buttons total?  (no joysticks, trackballs, or spinners)  just something simple.  (I don't want to do the keyboard hack unless there is a simpler version)
I know they will all work, but I don't need the top of the line here.
Also, what can I use for a power source for lit buttons that require 14v?
http://www.happcontrols.com/pushbuttons/5400044x.htm]http://www.happcontrols.com/pushbuttons/710004tx.htm[/url
and
[url]http://www.happcontrols.com/pushbuttons/5400044x.htm
I believe the PC fan plugs are only 5v (correct?)
MPTech
   Better living thru technology!   ;-)
NickS
  • Last login:September 11, 2014, 06:59:58 am
Re: Keyboard encoder for a Jukebox and power source for lit buttons
« Reply #1 on: May 26, 2007, 04:42:26 am »
Funny that you have posted this as I was about to ask the same question. My order of the Happs Low Profile Buttons arrived a couple of days ago but I have not yet figured out a solution for the 14v bulbs.
I orderd a mixture of the following:
http://www.happcontrols.com/pushbuttons/5700044x.htm
http://www.happcontrols.com/pushbuttons/5700045x.htm
Which jukebox software are you using?.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #2 on: May 26, 2007, 06:35:56 am »
An I-PAC 2 would do this, or a Mini-PAC with button harness if you want to save time with the wiring. There are many other alternatives.
You could probably use 12 volts for the lamps. Just connect into a spare PC disk power connector. The yellow wire is 12 volts, black Ground.
Andy
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #3 on: May 26, 2007, 01:20:55 pm »
The 161 bulbs will work fine at 12V.  They are mainly used in auto industry, where voltages range from 11-14 Volts.  I wouldn't spend any time, money, or thought on running these at 14V rather than 12V.
I think that the mini-pac may be on sale right now, too...  There was a thread that Andy posted somewhere stating this recently.
If I do not respond to your post in a timely manner, feel free to PM me.
MPTech
« Reply #4 on: May 26, 2007, 01:49:11 pm »
The Mini-Pac sale is what triggered me to post this topic.
BUMMER!  I just ordered the Mini-Pac & Mounting feet and when I went to checkout, I was charged $14 for DHL shipping (and given no alternatives!)   I'm not in a hurry it can take a week or 2.   $14!  C'mon.  There's a dropdown selection for shipping and a "change shipping" button, but no options.
What gives!?!?!?!
MPTech
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #5 on: May 26, 2007, 02:07:37 pm »
Did you use this link?
http://www.ultimarc.com/JShopServer/section.php?xSec=11
The first mini-pac listed shows as "Free Air Mail shipping".
NickS
« Reply #6 on: May 26, 2007, 04:38:59 pm »
Thanks.
Sorry to sound clueless. I have hacked a power supply before for coin door lights but for 20 bulbs is there a particular way to wire them up (eg daisy chain style etc) ?.
MPTech
« Reply #7 on: May 26, 2007, 07:41:19 pm »
HoopZ,  THANKS!!!!
your link worked, with no shiping!!!!!!!!  :notworthy: :notworthy: :notworthy:
(I don't know why the other link was different)
THANKS again!   I ordered it just fine!
MPTech
MPTech
« Reply #8 on: May 26, 2007, 07:46:00 pm »
I just realized the difference.  I wanted the one with the cable, it charges the shipping, the one without does not charge shipping.
shoot, I ordered the wrong one!
MPTech
Hoopz
« Reply #9 on: May 26, 2007, 08:51:36 pm »
I should have posted this link also. Sorry!
http://forum.arcadecontrols.com/index.php?topic=63236.0
