| Main > Main Forum |
| Need Help Looking to connect more than one N64 controller to my mame machine |
| << < (2/2) |
| SavannahLion:
I never said Lik-Sang made the Adaptoid, they were a supplier/importer for products of this nature. My OT rant was just about how it's annoying to run around on multiple sites looking for products. Anyhow, I get the impression, from reading the description, that, "....only a single controller may be connected at any given time." is referring to the fact you can't connect a PSX and a N64 controller at the same time. Not so much connecting multiple adapters to the PC. The adaptoid is preferred due to better support for a wider variety of N64 controllers. That's the impression I get. :dunno |
| fjl:
I use a logitech Dual Action controller. It mostly mimics the PSX controller in layout. Cost me $18 bucks. It works on the N64 emulator pretty well. Not sure if you are just looking for the thrill of using an actual N64 controller on your PC, but just about any cheap PC controller will do the job of working on mame. My only dissapointment about this logitech controller is that the analog controls have a square frame so when you move up it doesnt stick into a little groove like the n64 controller so its likely to slide in the up-right or up-left position. I haven't checked but perhaps they have PC controller with these little grooves now. |
| Xam:
--- Quote from: efjayel on May 23, 2007, 02:28:55 pm ---I use a logitech Dual Action controller. It mostly mimics the PSX controller in layout. Cost me $18 bucks. It works on the N64 emulator pretty well. Not sure if you are just looking for the thrill of using an actual N64 controller on your PC, but just about any cheap PC controller will do the job of working on mame. My only dissapointment about this logitech controller is that the analog controls have a square frame so when you move up it doesnt stick into a little groove like the n64 controller so its likely to slide in the up-right or up-left position. I haven't checked but perhaps they have PC controller with these little grooves now. --- End quote --- I've had success also with the logitech...good controller for the price. Xam |
| johnnya:
You can hook up more than 1 of those boom psx/n64 controllers to mame. I've had 4 running at the same time with n64 controllers, and it works fine. |
| vartech:
--- Quote from: johnnya on May 23, 2007, 11:12:10 pm ---You can hook up more than 1 of those boom psx/n64 controllers to mame. I've had 4 running at the same time with n64 controllers, and it works fine. --- End quote --- can you tell me what type of controllers are you using OEM n64 or aftermarket also what is you button layout since they each have 16 buttons. |
| Navigation |
| Message Index |
| Previous page |
