Main > Everything Else
Moving full ply/mdf sheets in a pickup?
<< < (10/12) > >>
horseboy:
Just when I though you got it.  :'(
knave:
...Sigh...
I've done it in my small pickup both with the gate up and gate down.  Eather way I use a few bungee cords hooked to the rear of the bed diagonally across the sheets and one across the ends of the sheets. Works fine.  I guess it's not quite the same because in a small P/U you need to slide the sheets in so one side rests on a wheelwell.
I agree use the gate up method and throw some bungees/rope/straps across it and at the end.
psik0tik:
It is amazing how a topic about "how to secure plywood" can turn into a dickfest. MDF doesnt usually slide around it has a amazing ability to static cling to other pieces.
shardian:
--- Quote from: knave on May 23, 2007, 01:49:08 pm ---...Sigh...
Why you kinky dog you! I guess you definitely aren't married. :laugh2:
Chris G:
 ;D  I can't believe that one lasted 3 hours.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
