Main > Main Forum
Anyone ever put a ball-top on an E-Stik or Happ Universal?
Cue-Ball:
Okay, so are we now 100% positive that the Happ stick and the E-Stik are not the same? I want to make sure because i was going to order the Happ since Ultimarc's shipping is so steep.
Still no answers on the ball top issue though. Nobody on this board has ever tried to attach a ball top to the E-Stik? C'mon, guys! I don't want to be the guinea pig on this one! ;)
Zeitgeist:
From the looks of it they ARE the same!
...just a different color handle & diffrent brand of microswitches.
You can do the same little trick with the switch plate on both of 'em.
shmokes:
Read that thread again. I don't know how you are getting from that thread that that is how it is meant to work.
That top square that shows above the control panel should not rotate. If it works for you that's fine, but it does not appear that you are using it the way it was meant to be used.
