Main > Main Forum
Bending plexi or lexan
Pages: << < (2/3) > >>
rampy:
here's an old thread discussing the idea old thread and here's his follow up... thread hope you have better luck.. but soujnds like his overlay was several bends/complicated... *Shrug*
ymmv,
rampy
Pixelhugger:
Once heated thoroughly plexi will bend with absolutely no resistance. 90' is no problem. You could probably bend it all the way back against itself. A blow dryer won't work - at least I'd be pretty surprised if it did. I've used a blow torch. The type of propane you buy in a aerosol sized can at Home Depot and fit with a brass nozzle also available there. Total cost is like $10.00 or so. I had never used a torch before but was bending plexi in minutes to make 2 aquariums to put inside old Macintoshes.
Be super careful NOT to heat to quickly or you'll get permanent tiny bubbles all over inside. Practice on scrap. And do it outside. To bend at 90' first place tin foil along a table edge (protect the hell out of the table if it's not a work bench) ;)  Run the torch evenly back and forth along the edge - try to keep the flame off the plastic, though it'll take longer to bend. You can touch the plastic with the flame but not for long- and you increase the risk of bubbling. When you see the plexi start to bow, remove the torch and help it along. If you feel resistance keep running the torch. Do not try to rebend it once it has begun cooling.....it'll snap. It'll take a few minutes to cool completely. Go slow. ;D
paulkortne:
This is SO easy (i just found this out today)!  Lexan can bend all the way back to itself, and it doesn't even have "stretch" marks on the first bend!  I just bent it with my hands.  It has some resistance, but can be done.  Your 90 degree bend would be very sharp and look great.  Skrew plexiglass
It bends very sharply.  Maybe only a centimeter at most.
     _______
Brad Lee:
But does it stay bent, or did you attach it to some kind of frame or shell?
This is whta I'm trying to cover- in a strange mix of 2D and 3D.
The blue line is the end dimension of my control panel- currently wood with lexan the same size
The green line is the side profile of whta I'd like to do with the plastic, kind of a wrap-around, as right now the front under my CP is wide open, and my cats like to go spelunking in the holes on either side
I think I'm gonna grab a 24x24 piece of lexan and one of my dummy CP pieces, put some braces in across the width so I have a solid edge to bend along and give it a try. Hopefully it'll be solid enough that I can remove the braces and jsut have the shell
Psyklops:
I'm pretty sure I've read that Lexan (unlike Plexi) can be cold bent, meaning it doesn't require heating, just some elbow grease.
Go to full version
