Main > Everything Else
Buzzy/staticy car speaker
<< < (2/3) > >>
psik0tik:
along the bottom near the floor pull the carpet back and look under the plastic molding on the bottom..check for the short near the door.
lanman31337:
Try a better ground from you head unit to chassis - this should clear up your problem.
ChadTower:
Thanks... tomorrow, I'm going to hook up a different speaker directly in the harness, see if it still buzzes.  That should test the head unit... and then if it passes, I can run a new line from there to the existing speaker, which should see if the problem goes away without that potential short.
A better ground... would that affect only one of four speakers?
ChadTower:
If it helps, I cut that speaker connection at the speaker this morning... on the way in to work, I cranked it the whole time and all three other speakers sounded strong and clear.
psik0tik:
then it's more than likely the speaker...a ground wouldn't make just one speaker buzz
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
