Main > Main Forum
KeyWiz Wiring Dilemna - PLEASE ADVISE!
Pages: << < (3/3)
tonyarcade:
I meant simple frontend.
Fozzy The Bear:
--- Quote from: tonyarcade on June 09, 2007, 02:40:02 pm ---I meant simple frontend.
Mame32 is the front end for Mame32..... It's built into it.
If you want a more arcade type frontend, then use regular version mame and a separate frontend.
Best Regards,
Julian (Fozzy The Bear)
RandyT:
--- Quote from: tonyarcade on June 09, 2007, 02:39:08 pm ---I figured it out!
The "ground" wire, which my electrician friend said is really a "neutral" was not hooked up properly to the stick.
"Neutral" is an AC term.  You are working with a  DC circuit, so he is incorrect.
Glad to hear you got it figured out :)
RandyT
tonyarcade:
What would a regular version MAME be? Mame 1.15 or .115 (whatever it is) from mame.net?
Which version would you suggest grabbing?
Hoopz:
You need to make sure the version of mame that you are using matches the rom(s) version that you have.
Pages: << < (3/3)
Go to full version
