Main > Everything Else
How 'green' are you?
mr.Curmudgeon:
No, it's a decent sized lawn. The mower runs for about 45mins or so. I had time to go over certain areas twice (tall grass needed to be mulched several times)
polaris:
--- Quote from: mr.Curmudgeon on May 15, 2007, 11:37:14 am ---
--- Quote from: polaris on May 15, 2007, 11:02:19 am ---and you think this is better for the environment
Isn't the atmosphere part of our environment?
my point is that you're displacing the pollution not removing it.its coming from the power station not from your back yard. the only way to truly have an effect is to use a manual lawn mower.
regarding power stations being less polluting for the energy they produce than acrappy lawnmower, is im sure true, but add to this the fact that national grids waste a collosal amount of the enegy they produce its still not at all efficient.
ChadTower:
Sounds bigger than my lawn, then. My whole lot is .27 acres, including the house, shed, driveways, brick path, and an area with no grass (pine trees). I'll look into these mowers when my current one finally bites it.
Or maybe a hand mower, if I can find one.
polaris:
--- Quote from: ChadTower on May 15, 2007, 11:46:08 am ---
what about a goat? removes the lawnmowing altogether
polaris:
--- Quote from: pinballjim on May 15, 2007, 11:47:42 am ---Lead schmead, in a hundred years we'll all be dead.
are you saying,'cos i'll be dead why should i care about what happens in a hundred years' or do you think the whole human race will be gone?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
