Main > Everything Else
How 'green' are you?
<< < (42/51) > >>
shorthair:
The cause was wind.
Samstag:
Air is a fluid.
DrewKaree:
--- Quote from: shorthair on May 23, 2007, 05:39:11 pm ---I didn't say they were caused by that. I said they could possibly be influenced by. Of particular import is the cause of the waves.
Patrick, assplain to him your theory of climate not being the same as weather.
shorthair:
Using his words doesn't make StrongBad your friend....although, you do come across sooo sexy when you're like that. Who said anything about climate? Still, climate is only part weather. It also includes region and the flora and fauna.
patrickl:
--- Quote from: DrewKaree on May 23, 2007, 11:49:57 pm ---
Why would I need to do that? I think he does understand that already.
It's not like they are completely unrelated, but what I was saying is that one freak weather day doesn't imply or disprove climate change and that getting an accurate weather report 5 days ahead is something different from a climate prediction. On the other hand, when the climate changes to allow more extreme weather conditions then of course you will see weather changes accordingly.
I still wonder why no one seems to think that finite natural resources running out is a problem. Why is it always about the climate change? Even for the most egotistical it should be obvious that decreasing oil reserves and decreasing oil production will hurt them even on a reasonably short term already (actually it does now already).
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
