Author Topic: Perferred Paint?  (Read 3327 times)
dndcollect
  • Last login:September 18, 2007, 09:09:54 pm
Perferred Paint?
« on: May 11, 2007, 10:53:03 am »
I am painting my cab this weekend and was wondering if anyone recomends a certain kind of spray paint, etc?
  • Last login:Yesterday at 07:54:28 pm
Re: Perferred Paint?
« Reply #1 on: May 11, 2007, 11:25:17 am »
I used Behr (Disney) to paint mine.  I used a high-quality foam roller and it's coming out pretty nice so far.  People will tell you to go with something a little pricier like Sherwin-Williams or something but I haven't had any problems with it.  I can't speak to spray paint though.
« Reply #2 on: May 11, 2007, 11:27:28 am »
Just for a bit more data, I've used Behr in my house with horrible results, and have used Sherwin Williams with excellent results, same tools and methods.   :)
I wouldn't paint a cab with canned spray paint.  Stenciling, maybe, but never a base coat.
dndcollect
« Reply #3 on: May 11, 2007, 11:47:24 am »
how do you go about getting around the difficult spots?
Chris G
  • Last login:April 16, 2023, 04:39:59 pm
« Reply #4 on: May 11, 2007, 11:50:24 am »
with a brush?
shardian
« Reply #5 on: May 11, 2007, 11:51:03 am »
What exactly do you mean by "difficult spot"?
suits00
« Reply #6 on: May 11, 2007, 12:07:46 pm »
i used the cheapest spary paint, a $1.00 a can. Truly i can't tell the difference between my cabinet and other cabinets that i have seen. I didn't prime or anything.
Kaytrim
  • I'm too nice a guy
« Reply #7 on: May 11, 2007, 12:11:11 pm »
Probably inside corners where a roller may not fit properly or small spaces.  I have a 3" square end and a 4" bull nosed end high density foam rollers that I should be able to start using this weekend.  I'll let you know how it goes.  One thing that everyone says and I understand why is to lightly sand between coats of paint.  This goes for both primer and color coats.  If you don't sand then the new coat will not adhere properly to the previous coat.
TTFN :cheers:
Kaytrim
« Reply #8 on: May 11, 2007, 12:26:09 pm »
For even more data and to be fair, I've never used Sherwin-Williams so I really can't compare the Behr paint jobs to anything... maybe everything in my house looks horrible and I just don't know it!
Chris G
« Reply #9 on: May 11, 2007, 12:29:00 pm »
How can anything Disney be bad?  It's the happiest place on earth!
« Reply #10 on: May 11, 2007, 12:34:15 pm »
Well, in the end, it didn't look horrible... it just took Behr 7 painful coats, on long and winding trim, to get full coverage.  After 4 coats you could still see through to the freakin' primer.
The other room, same trim, the SW paint did it in two.
Jeff AMN
    • Gamer Theory
« Reply #11 on: May 11, 2007, 12:47:44 pm »
Huh, I've never had any issues with Behr. On my cab, the Behr paint looked a million times better than the original cab's paint after only two coats. I went with three, but two would have been just fine.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #12 on: May 11, 2007, 12:51:48 pm »
Why not?  I've been seeing approvals for spraying around (even over smooth roller)...
What would you suggest for someone on a budget?
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #13 on: May 11, 2007, 01:05:46 pm »
Instead of a brand, I recommend using an oil based enamel. A satin black enamel is a pretty tough finish, and a close match for what was on many original games.
bleargh
  • Last login:Yesterday at 01:22:37 pm
  • ribbit...
« Reply #14 on: May 11, 2007, 01:12:02 pm »
Had similar problems when painting the bathroom when we moved in.... stupid  :censored: at HD sold us deep red Behr paint using the base for lighter coloured paint.  Five coats on (and two days later), and I could still see through the damned paint.
Went back to HD and yelled at the person behind the counter about it being crap paint and he looked at it and said "no wonder, what dumb-ass sold you that? that's for light colours".  Uh, the other dork in your department...  Gave us a new can of the same tint but using the base for deep colours.  One coat covered everything up.  Used the same deep base can in another room and only needed two coats to get it a nice and rich colour.
So... if you're putting on any sort of deep/dark/rich colour, be sure that they tint it using the right base can.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #15 on: May 11, 2007, 01:15:58 pm »
If you have kids, make sure whatever paint you choose can take being scrubbed.  Sooner or later they will make a mess somewhere on the cab and of course it won't be found until the mess is dry.
Jeff AMN
    • Gamer Theory
« Reply #16 on: May 11, 2007, 01:46:10 pm »
Mr. Clean Magic Eraser is a blessed tool for cleaning up cabinets.
Zakk
  • Last login:May 06, 2024, 10:05:51 pm
« Reply #17 on: May 11, 2007, 02:27:54 pm »
Behr is a HORRIBLE paint, there's no two ways about it.  I've used it extensively and and can honestly say it is next to CIL BULK-INDUSTRIAL paint in terms of quality.  There is references on the net to how many polymers or something a paint has, and how well it will bond, but keep away if at all possible.
I currently use Benjamin-Moore paint, and it is absolutely killer.  Twice the price, but will cover 3X as much.
« Reply #18 on: May 11, 2007, 02:32:23 pm »
Spray cans will not be cheaper anyway, there's not all that much in a spray can.  And I've yet to see anyone here recommend spray cans for a base coat on a cab.  They're just not designed for that.
When people say spray, they usually mean with a paint sprayer, and a decent paint sprayer isn't cheap.
shardian
« Reply #19 on: May 11, 2007, 02:32:34 pm »
The Behr argument has popped up on here multiple times, and there is always 50/50 people who like/dislike it. All I can figure is that their quality control is sucky for that kind of polarizing opinion.
Personally, I decided to try Behr in the baby room because their white is much brighter than any other brand. After 2 gallons of semi-gloss on a twice primed, 10'x12' room, I said screw it and bought some cheap Enterprise paint and covered it up. The stuff just does not cover very well at all, even though it uses more than twice the amount of paint other brands require for the same area. I definitely would not recommend it.
Organic Jerk
    • OmeshPersaud.com
« Reply #20 on: May 11, 2007, 02:58:40 pm »
Arrghh.. so what would you suggest for someone on a budget?  Or should my budget just go out the door?
Are the smooth rollers a better idea for me?
shardian
« Reply #21 on: May 11, 2007, 03:02:16 pm »
If you are on a budget, go to walmart, buy a gallon of Enterprise,a small foam roller, and some extrafine grit sandpaper. If your budget can't fit that, then yeah you better throw it out the window. ;D
« Reply #22 on: May 11, 2007, 03:03:16 pm »
Depends on how picky you're going to be about the finish.  You can get a decent finish from a low end paint sprayer if you use the tool well.  It will never be mirror perfect, but then again, most people can't get that from a pro setup.
Many here have gotten quite good results from foam rollers.  I wouldn't toss that out as a method.
Zakk
« Reply #23 on: May 11, 2007, 04:40:23 pm »
It has nothing to do with quality control, it's a simple fact that behr only sticks well to certain surfaces (like unprimed drywall).   For anything else, it smears, runs and requires multiple coats.  The people that say they like behr paint honestly just don't know any better, or lucked out and painted an unprimed, unpainted surface.
« Reply #24 on: May 11, 2007, 04:41:30 pm »
It seems odd to me that a mass production consumer paint would have trouble sticking to quality primer.  I use Kilz on everything.
Joystick Jerk
  • Last login:October 22, 2023, 08:18:08 pm
  • Slave to the stick.
« Reply #25 on: May 11, 2007, 05:10:28 pm »
I used a black melamine paint on my last cab. Came out great and is tough as a rock. Only downside is it was hard to find, and damn expensive. The only place I could find it was at Benjamin Moore, and it was $50 a pot.
Zakk
« Reply #26 on: May 11, 2007, 07:56:31 pm »
even on meat loaf?  you monster.
vintagegamer
  • Last login:November 16, 2014, 07:41:40 am
  • Seasoned Arcade Survivor.
« Reply #27 on: May 11, 2007, 10:27:31 pm »
I've actually been using Behr paint in my home for years now, and just bought some tonight to touch up my Ms Pac cab..  I'll provide an update when it has dried (tomorrow AM).
VINTAGEGAMER
suits00
« Reply #28 on: May 12, 2007, 12:12:46 pm »
If you're on a budget, i recommend spray paint, and actually used spray paint on my whole cabinet. Yes, spray cans
Jeff AMN
    • Gamer Theory
« Reply #29 on: May 12, 2007, 06:05:58 pm »
Well, I just finished painting a cab this morning using...wait for it...BEHR PAINT. I used a black semi-gloss and it looks great. After just one coat it's really looking good. After three, it should be perfect.
This isn't the first time I've used Behr. I am using the foam rollers each time around, however, and I think that makes ANY paint go on much better.
« Reply #30 on: May 12, 2007, 06:10:06 pm »
Only if it has onions in it.  If there are no onions, it's just horseboy's mom.
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #31 on: May 12, 2007, 07:00:46 pm »
I used Rust-Oleum oil based Black Satin as I have 4 children and I wanted a tough enamel finish. I highly recommend an oil based as it's hard as nails! Also, go with a oil based primer and have it tinted to what ever color you are using. Take the time and use two coats sanding down to about a 300 grit and it will hide any minor blemishes you have in the wood underneath. I used a white high quality dense roller, but will probably use a sprayer next time I tackle one of these.
My old user name was marlborroman13, but I kicked the habit many years ago!
Zakk
« Reply #32 on: May 12, 2007, 10:20:35 pm »
Oil based through a sprayer is a helluva nasty cleanup.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #33 on: May 13, 2007, 09:15:27 am »
Here in Canada, Benjamin Moore makes a black oil enamel that is the BLACKEST BLACK I have ever seen and covers brilliantly. It comes as black in the can (no tinting) and is a good, tough, solid black.
« Last Edit: May 13, 2007, 09:24:08 am by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
spacies
« Reply #34 on: May 13, 2007, 11:51:07 pm »
I'm a squirter  :laugh2:
As long as it comes out of the end of gun, I am happy.
Current paint of choice, 2k, or 2 pot. Base coat and clear coat.
The same stuff your car is painted with.
Goes on dead flat and has the best shine and wear.
You have to be careful using it though. Full air fed respirator etc.
I am currently working on a project and I will post some pics in a couple of weeks when it's done.
