Author Topic: Coin door confusion  (Read 1047 times)
Spyridon
  • Last login:April 30, 2021, 02:47:05 pm
Coin door confusion
« on: May 10, 2007, 12:41:19 pm »
I would like to include a working coin door (2 player) in my cab.  I'm really confused by Happ's website.  I can't tell by the descriptions if they come with everything I need (and their technical support is even worse than the website)
Can someone recommend the HAPP part numbers I need that will give me a complete working coin door?
unclet
Re: Coin door confusion
« Reply #1 on: May 10, 2007, 12:53:29 pm »
I can not, however, finding a nice complete coin door on Ebay is fairly easy and a heck of a lot cheaper than buying everything through Happs.
A little black spray paint, new coin inserts and some locks, these would be great cheap doors:
http://cgi.ebay.com/Over-Under-Coin-Door-Arcade-Game-Quarter_W0QQitemZ300109462577QQihZ020QQcategoryZ13718QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Coin-Door_W0QQitemZ110123835196QQihZ001QQcategoryZ13718QQrdZ1QQcmdZViewItem
However, if you absolutely need to buy everything new from Happs then at least order through "ponyboy" or "divemaster".  They both deal in obtaining parts from Happs for cheaper than buying direct and are well known in the BYOAC community.
« Last Edit: May 10, 2007, 12:58:45 pm by unclet »
moriartyds
  • Last login:November 05, 2007, 09:09:39 pm
« Reply #2 on: May 10, 2007, 03:24:25 pm »
Depends on what style you want, but a fairly standard 2 person over/under coin door is: 40-0038-00
http://www.happcontrols.com/coindoors/40003800.htm
I definitely agree with checking ebay or Pony/Dive in the trader's forum ... you'll save lots of $$.
Crowquill
  • Last login:December 03, 2021, 05:02:15 pm
« Reply #3 on: May 10, 2007, 04:21:13 pm »
I don't want to sound like a broken record, but I'd hit eBay too. With a door that's not dented or bent and a can of spray paint, you can have a door that looks like new for less than 20% of the cost of a new Happ door.
Spyridon
« Reply #4 on: May 10, 2007, 05:18:26 pm »
Thanks for the advice.  What are your thoughts on this one:
http://cgi.ebay.com/ARCADE-VIDEO-GAME-COIN-DOOR-UNDER-OVER-JAMMA-Complete_W0QQitemZ200087826074QQihZ010QQcategoryZ13718QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Looks like everything I would need.  A little more than some of the auction items, but it looks like it doesn't need any clean up.
moriartyds
« Reply #5 on: May 11, 2007, 10:30:23 am »
Looks fine.  I'm not sure what the additional sound wiring he has on there is, but as long as it is working it should do the trick for you.
You might want to email the seller and confirm whether it is set up to take quarters, tokens, or something else.
unclet
« Reply #6 on: May 11, 2007, 11:28:41 am »
Seems like a lot of money to me ....
IF you do not want to do any work and save money ..... it seems like this one will do for half the price:
http://cgi.ebay.com/OVER-UNDER-VIDEO-GAME-COIN-DOOR-STRAIGHT_W0QQitemZ190112057311QQihZ009QQcategoryZ13718QQrdZ1QQcmdZViewItem
I guess I am not sure if the light bulbs work, but those a extremely cheap to replace.    Seems like nice inserts and no paint required on this one ....
... however, which ever door you end of wanting/getting, as long as it suits you, then that is all that matters ......
« Last Edit: May 11, 2007, 11:32:58 am by unclet »
Crowquill
« Reply #7 on: May 12, 2007, 12:35:39 am »
You don't have to limit yourself to over/under doors either. This one isn't bad.
Or if you like the over/under's how about this one. Personally, I've always been a bit put off by shipping to/from Canada, but for that price...
Due to the weight of these things make sure you figure in the shipping cost. Then again, you pretty much have to do that anymore for most anything on eBay.
