Author Topic: Best way to wire Ipac? Solder?  (Read 3120 times)
dndcollect
  • Last login:September 18, 2007, 09:09:54 pm
« on: May 09, 2007, 05:59:34 pm »
Here is the deal, i wired my controls to an Ipac and for some reason some of the buttons when I press once, they register twice, so if i want to punch, it will punch twice instead of once.
i did the "twist" method, and I am wondering if soldering is the best way?
  • Last login:Yesterday at 07:54:28 pm
Re: Best way to wire Ipac? Solder?
« Reply #1 on: May 09, 2007, 06:08:52 pm »
Maybe you have a faulty iPac?  Soldering is completely unnecessary.  Strip the wire tips and screw them down to the iPac.  I use .187 female quick disconnects to wire the microswitches - no soldering required.
dndcollect
« Reply #2 on: May 09, 2007, 06:11:04 pm »
maybe.  yesterday it seemed ok, however i pulled out the joystick to rewire it and perhaps some wires got disloged.
its a B to go back in and rewire because of how the cab is made, i just wanted to make sure before i do that.
BobA
  • What Me Worry?
« Reply #3 on: May 09, 2007, 06:13:29 pm »
If you are talking the switch end then you need to do more than twist the wire.
Suggest solder or
dndcollect
« Reply #4 on: May 09, 2007, 06:15:38 pm »
yeah, switch end is what i mean, sorry i didnt make that clear.
dndcollect
« Reply #5 on: May 09, 2007, 06:16:56 pm »
here is a dumb question, what is that red thing and how do you use it? i have a bag of them.
me= :dizzy:
NoOne=NBA=
« Reply #6 on: May 09, 2007, 06:36:48 pm »
They are quick disconnects.
You crimp them on to the end of your wires, and then they just push onto the tabs on the microswitches.
When you need to put in a new switch, you can quickly disconnect the wires, and replace the switch.
ahofle
    • Arcade Ambience Project
« Reply #7 on: May 09, 2007, 06:50:51 pm »
I had this problem a while back and it turned out to be microswitch 'bounce'.  You can test this by taking a switch that doesn't exhibit the double behavior and swap it with a 'suspect' switch.  If it stops double-pressing, then it's likely the switch.
dndcollect
« Reply #8 on: May 09, 2007, 06:57:57 pm »
so do i strip the wires, put them in a hole and then crimp it?
also if i am daisy chaining do i twist 2 together and then crimp?
NoOne=NBA=
« Reply #9 on: May 09, 2007, 07:25:34 pm »
Yes, and yes.
« Reply #10 on: May 09, 2007, 07:32:46 pm »
me= :dizzy:
Someone wasn't paying attention in Sex Ed.
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 12:51:56 am
« Reply #11 on: May 09, 2007, 08:40:28 pm »
What Chad means is that you have a female connector there in the photo.
The male connector is on the microswitch.
Now, if you paid attention in sex-ed then you'll know what to do next to make everyone happy :)
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #12 on: May 10, 2007, 07:26:14 am »
What game are you playing? I'm asking because some capcom (most actually) games have what's called "negative edge". The game registers a press as you press the button of course, but it also registers it as a press upon releasing the button.
It's 9am. I'm calling it a nite.
Tiger-Heli
    • Tiger-Heli
« Reply #13 on: May 10, 2007, 02:18:49 pm »
I think Chad had a different meaning, but I'll let it go at that . . .
« Reply #14 on: May 10, 2007, 02:38:59 pm »
It was a double entendre.   ;D
Tiger-Heli
    • Tiger-Heli
« Reply #15 on: May 10, 2007, 03:03:18 pm »
But not a menage a trois!  ;D
« Reply #16 on: May 10, 2007, 03:04:55 pm »
It just occurred to me that there was a discussion on the meaning of the Word of Chad and I interrupted it.
Carry on.
Tiger-Heli
    • Tiger-Heli
« Reply #17 on: May 10, 2007, 03:19:47 pm »
Not since the 2000 election.
Carry on.
But of course!!!
Zebidee
  • Trade Count: (+9)
« Reply #18 on: May 10, 2007, 06:49:21 pm »
Sounds comfy ....
Did someone say double?  I'll have one of those too ...
