Author Topic: Switch Question  (Read 1349 times)
Trebeck
  • Last login:October 12, 2021, 11:01:21 am
  • "The Arcade" - Build #4
Switch Question
« on: May 09, 2007, 01:27:03 am »
Hey all,
Quick question...
On a PC the power switch clicks twice when turned on.  What kind of switch is this?
Beck
Kevin Mullins
    • Me on Myspace
Re: Switch Question
« Reply #1 on: May 09, 2007, 01:50:32 am »
Does it click twice again to turn it OFF ?
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Switch Question
« Reply #2 on: May 09, 2007, 02:05:58 am »
PC's made in the last several years have a "momentary contact" switch.  Older ones used a push-to-toggle switch.
Trebeck
Re: Switch Question
« Reply #3 on: May 10, 2007, 01:57:25 pm »
hmmm. OK here's what it does.
turn on
if you push thebutton it has two clicks and it powers up fine.
if you hold the button it will turn on then off after about 4 sec.
turn off
push the button (two clicks) won't do anything.  I guess this is a safety feature for when you hit it with your shoe.
Hold it in and it will power off after about 4 sec.
Is this a momentary contact switch?
See I am looking for illuminated switches to make my new cab look sweet.  But I think most of them are simple on/off switches.  This is OK as I have one on my cab right now.  But the trick is you have to throw the switch to "on" then "off" so it won't power down after 4 sec.  This is very confusing to newbies.
Know what I mean?
Beck
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
Re: Switch Question
« Reply #4 on: May 10, 2007, 03:13:57 pm »
Yep, that's a momentary contact switch
Re: Switch Question
« Reply #5 on: May 10, 2007, 03:16:06 pm »
Trebeck
Re: Switch Question
« Reply #6 on: May 17, 2007, 12:35:06 am »
You guys rule.
Beck
