Main > Everything Else
Rules for Quote FU?
<< < (2/6) > >>
ChadTower:
--- Quote from: horseboy on May 09, 2007, 11:08:21 am ---.
shardian:
If there are no rules to quoting in the political world, why should there be here? ;D
ChadTower:
--- Quote from: shardian on May 09, 2007, 11:17:15 am ---No rules means we can do anything.  Sometimes, I like to stick my fingers under my armpits and then I smell them like this.
horseboy:
shorthair- You are wrong. You added punctuation that wasn't there. Cheater.
bfauska- Here is the deal. We will take this gem as an example...
--- Quote from: shorthair on March 27, 2007, 07:17:42 pm ---Perhaps, one of these days, some of you will start asking questions before your penis gets in the way. (Regardless, I'm enjoying my time.)
Now we can get rid of that first part as it probably won't be needed. YOu will be left with...
--- Quote from: shorthair on March 27, 2007, 07:17:42 pm ---some of you will start asking questions before your penis gets in the way. (Regardless, I'm enjoying my time.)
From there you can clip off more from either end or both ends to make the sentence mean whatever you want. Such as...
--- Quote from: shorthair on March 27, 2007, 07:17:42 pm ---your penis gets in the way. (Regardless, I'm enjoying my time.)
or...
or both ends...
--- Quote from: shorthair on March 27, 2007, 07:17:42 pm ---start asking questions before your penis
But you can't take out certain words just to make it work better. Such as...
--- Quote from: shorthair on March 27, 2007, 07:17:42 pm ---your penis gets in Regardless
or...
--- Quote from: shorthair on March 27, 2007, 07:17:42 pm ---some of your penis gets in the way. (Regardless, I'm enjoying my time.)
No adding stuff or mixing up words obviously. You are getting into a mangle if you go that route.
So, ya, just clip from the ends, not the middle, and don't add anything. Even punctuation
Rarely, but sometimes it is acceptable to clip from the middle if you add an ellipsis. This is highly discouraged, and is usually reserved for the beginners or the elderly.
--- Quote from: shorthair on March 27, 2007, 07:17:42 pm ---you will start... your penis
Chris G:
I would never add anything not originally written or completely hack something up.  I'm pretty sure I'm guilty of clipping out middle sections, but that can happen in the midst of Cooperative Quote Fu.
May I suggest another new term for this discussion: Quotiquette
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
