May 09, 2024, 02:52:25 am
Will you be wiring it back to the original board?Do you have the connector from the board to your wires (is that what you're asking)?If you're not using the original board, it really doesn't matter whether the wiring harness is original. So assuming you need the original harness pinouts... http://users.adelphia.net/~68hc11/pacfile/pacfile.htm
The colors might be the same as a picture, or they might not.It would probably be best for you to follow the wires back to where they came from to see what they are. This should be easy for the CP. The monitor might be a bit difficult though.
