Author Topic: Advanced VGA Pinout?  (Read 1922 times)
SailorSat
  • Last login:Yesterday at 11:50:59 am
    • For Amusement Only e.V.
« on: May 06, 2007, 09:28:40 pm »
Hi!
I am trying to connect two Arcade Monitors with Ultimarcs VideoAmp to ONE Videocard.
My problem is quite simple.
Neither my NVidia card, nor my ATI card detect a monitor on the DVI port.
It DOES work if I use a normal VGA Monitor, so I suppose I need to connect more than just R, G, B, H-, V-Sync and GND.
Anyone know which pins i need to connect? I've heard something about Pin 11 connected to GND, but didn't try that one yet.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 02:20:28 pm
Re: Advanced VGA Pinout?
« Reply #1 on: May 06, 2007, 10:05:39 pm »
Standard Arcade Monitors are 125khz
Pc Monitors Svga/Vga are 31khz+
First you need to drive your Video Card to output the 15khz before you see anything on the Standard Arcade Monitor. Or the easy way (a bit of $$ involve), get yourself an Arcade VGA Video Card.
« Last Edit: May 06, 2007, 10:07:29 pm by Thenasty »
Free VGA Breakout Cable
SailorSat
« Reply #2 on: May 06, 2007, 10:10:34 pm »
Thanks for your reply.
Yeah, my cards output 15KHz on both heads.
Also, an ArcadeVGA won't output 15KHz on the DVI Port :)
Like I said, my only problem is that the cards don't "sense" a monitor with the J-PAC or the VideoAmp.
Multiple Monitors should be visible in your video cards settings, i.e. the Catalyst Control Center.
Thenasty
« Reply #3 on: May 06, 2007, 10:14:55 pm »
I'm assuming your card only has DVI connections. Is there a VGA adapter/converter used ?
If so, some Arcade monitors need the V/H sync separated so, you need the open the half moon shape on the AMP and wire the V/H synch separately.
SailorSat
« Reply #4 on: May 06, 2007, 10:19:20 pm »
Hi.
My cards have one VGA, one DVI and a TV-Out.
Yeah, there is a DVI-VGA Adapter used, thats not the problem.
As soon as I plug a normal VGA Monitor in the system say "Hey! Theres a second monitor".
But it doesn't with the J-PAC or the VideoAmp.
Also, both heads are active on boot, and the DVI disables as soon as Windows loads up.
The ATI card does not detect a Monitor on the VGA connecter either, but I guess they leave VGA enabled as a fallback.
Thenasty
« Reply #5 on: May 06, 2007, 10:29:21 pm »
does the VGA port work and and the DVI one ?
Confuse about having 2 monitors using the JPAC (do you have 2? and AMP ? )
I have connected 2 Arcade monitorsbefore. All I did was connect VGA PORT to AMP and both RGB/V/H/ sync WIRES on both monitors were twisted as one and BINGO, it work. Both images/game are on the 2 monitors.
SailorSat
« Reply #6 on: May 06, 2007, 10:43:59 pm »
Okay a more detailed info :)
I got two cabs, one with a Hantarex Polo, and the second one with a Hantarex MTC 9110
Theres a VGA-Amp attached to the Polo, and a J-PAC to the MTC 9110.
Right now the MTC 9110 is mounted vertical and the Polo is mounted horizontal, and they are driven by two Radeon 9200SE (one AGP and one PCI).
So I can play vertical games on the vertical monitor and vice versa.
Also I can play dual screen games on dual screens, as long as I turn the MTC 9110 to horizontal.
I recently managed to programm both heads on a NVidia GeForce 6600GT (and my 7600GT later on) and want to swap the two (quite old) Radeons out and put the 6600GT in.
However, I can't enable the seconds head because the NVidia drivers keeps saying theres nothing attached to it.
So I need to know how a graphics card does sense a monitor connected.
As for my test, I attached an old 15" VGA monitor and it was INSTANTLY detected, and it doesn't support DDC for sure, also my 29" VGA is detected instantly after plugin in, so it needs to be some simple "close on connect" switch.
I've attached some pics...
Here we got the MoBo.
And the two Radeons
Some shots in "single screen" mode.
And in "dual screen" mode.
P.S. Yeah... those pics are quite old, done with a real crappy Handy Cam ^^
« Last Edit: May 06, 2007, 10:45:32 pm by SailorSat »
SailorSat
« Reply #7 on: May 07, 2007, 02:53:31 am »
update on myself...
it seems modern cards sense an analog monitor by the 75 Ohm resitors betwen the RGB Pins and their ground.
however, neither die j-pac nor the videoamp do have these resistors, and that seems to be why they are not detected as analog vga monitor.
if i just connect 3 75ohm resistors on the vga connector on my j-pac, would that work?
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
« Reply #8 on: May 07, 2007, 04:04:32 am »
try it!  I had a similar problem before.  I had a compsoite video output on a mini-itx board that would work properly with a regular television connected, but it would not work with my car lcd composite video input: The lcd would not provide 75 Ohm load without signal sensed, and the signal would not be sent from the motherboard without 75 Ohm impedance sense.  I placed a 75 Ohm resistor from the composite video output to the signal return (ground) an it worked.
