Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
Pages: << < (66/485) > >>
SailorSat:
That should work.
gique:
should i attempt to rotate the display 1st, then switch the resolution, or the other way..
secondly I've been having problems trying to get the modeline calculated - the calculators i've used wont accept that resolution
can anyone assist? 240x320 (or 240x321) @ 15khz
thanks as always.
SailorSat:
nanana, keep the default resolution 321x240, as vertical displays work exactly the same way as horizontal ones.
just the image get rotated by the graphics adapter.
just select rotated 90° in your adapters display options.
Silver:
--- Quote from: SailorSat on February 11, 2008, 03:56:01 pm ---Yup.
However you will need some kind of "tool" for it.
I think I'll create something like that.
Hey,
Any thoughts/progress on this?
SailorSat:
Didn't go any further than some theoretical test on that yet.
Still waiting for some new cards to test out.
p.s. Radeon HD 2400 Pro works fine with custom resolutions (Pixel Clock needs to be 7.12MHz or higher)
Go to full version
