Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
SailorSat:
--- Quote from: bent98 on February 08, 2008, 06:25:25 pm ---I did also see the resolution in forceware custom resolution tab. I tried running pacman and edited the pacman.ini file to reflect 352x288@57
I didnt seem to work. I did not remove orginal modeline 352x288 custom15khz.txt.
I think you said you can have two same resolutions co-exsist.
What am I doing wrong sailor?
Wait... I'll just take a look in my magical orb...
Don't know what you did :)
If you see the resolution in the forceware you should also see TWO refresh rates (57Hz and 60Hz)
bent98:
Yes I do see two.
I then edited pacman ini and updated the resolution to all reflect the proper refresh rate 352x288@57
than ran pacman
Once I ran PACMAN it seem to run it at the default 352x288 rez. Is there something im missing?
SailorSat:
Try running MAME with -verbose and look what it says.
bent98:
I removed the orginal res in custom15.txt and then it tried to grab the custom rez u made.
Only thing was monitor couldnt sync to it.
o well
Ummon:
--- Quote from: SailorSat on February 08, 2008, 01:34:19 am ---
--- Quote from: Ummon on February 07, 2008, 07:36:04 pm ---I don't know what in your build would make it different regarding native res.
cabMAME doesn't stretch die image to full resolution as base mame does.
Um...when I select D3D on cabmame, I get a very little image.
Here's a question for you: I notice different timings of the same resolution will shift the image around the screen. Is it possible to create a timing specific to one's hardware that will minimize the amount of monitor adjustment of the image?
