Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
Silver:
Interesting modelines - I've got an old NEC presentation monitor stored away that will genuinely do 15-31Khz. I'll have a test at some stage...
Ummon:
--- Quote from: SailorSat on February 07, 2008, 04:12:22 am ---Either set Direct3D Version to 8 in MAME, or try DirectDraw.
Ahem. gaijin HAS to use DirectDraw to properly display native resolutions. If you want to know why, gaijin, read the Ultimarc monitor faq.
--- Quote from: SailorSat on February 07, 2008, 11:15:04 am ---Be VERY carefull :) I don't belive there are that many monitors that support 15kHz - 31kHz, most support only 15-16kHz, 24-25kHz, 31+kHz.
This one can. It spans something like 14.5-23khz, then jumps I think to 25-31.5, and maybe jumps again.
--- Quote from: Silver on February 07, 2008, 03:27:09 pm ---Interesting modelines - I've got an old NEC presentation monitor stored away that will genuinely do 15-31Khz. I'll have a test at some stage...
Not only a good test device, but also a good project monitor. What are you using soft15 with?
SailorSat:
--- Quote from: Ummon on February 07, 2008, 04:44:32 pm ---Ahem. gaijin HAS to use DirectDraw to properly display native resolutions. If you want to know why, gaijin, read the Ultimarc monitor faq.
Not really... Hey COULD be using cabMAME ;)
Ummon:
--- Quote from: SailorSat on February 07, 2008, 05:41:02 pm ---Not really... Hey COULD be using cabMAME ;)
I don't know what in your build would make it different regarding native res. By the way, no more error. I have a suspicion it was a virus/malware thing that required an update in software.
bent98:
I used a low res modeline generator and I get different number sailor. How do you cacluate the ones you came up with?
Also I tried using new build of soft 15 and when I click on install user
give me 'runtime error 9' subscript out of range
I did have a usermodes.txt with
modeline '352x288 17,7kHz 57Hz' 8,25 352 368 408 464 288 289 292 312 -hsync -vsync
Once I took out usermodes.txt It let me install user. What am I doing wrong?
