Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
SailorSat:
That more sounds like it doesn't work at all. You shouldn't be able to see anything on the LCD after the reboot.
gaijin4life:
So the fact that I can see windows on the LCD monitor means that it's not working? If it does work, I should get an "out of range" message, then?
If that's the case, it isn't working, then, even though the install program seems to indicate that it thinks it's installed and working.
Any ideas on what I can check/change?
The one thing that may be causing problems is that this motherboard has a built-in AGP Intel845GL video circuit. I've disabled it, but it might be worth mentioning. I initially tried installing Soft15khz with that, but it would only show up greyed out and was not selectable, so I disabled it and put the Matrox card in.
SailorSat:
Hm... What driver version is "the newest"? Should be something like 5.92 or 5.94.
Do you have any other card available? (a GeForce or a Radeon?)
*EDIT*
The OnBoard Intel shouldn't interfere.
gaijin4life:
Version is 5.33 006
Where is the 5.92 version for the PCI Millennium II? I didn't see anything that high on Matrox's site for that card.
Edit: Nevermind. I found 5.82.018 in their legacy section. I'll try that now.
SailorSat:
Hm...
http://www.matrox.com/graphics/en/corpo/support/drivers/latest/home.php
Last version for the Millenium II on XP should be 5.82
http://www.matrox.com/graphics/en/corpo/support/drivers/files/w2k_582.cfm
