Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
Pages: << < (56/485) > >>
bent98:
--- Quote from: SailorSat on February 06, 2008, 12:46:33 pm ---
--- Quote from: bent98 on February 06, 2008, 12:41:10 pm ---1) I am not sure I understand. Can you explain further. Do I still need add:
<CUT>
or is that incorperated into the new version of soft 15.
No it's not, as it works fine on most cards without those changes.
So for clarification if I still need the custom15khz.txt what do you you mean by "accepts modelines with the "doublescan" flag"??
I dont want to be bothersome I just am not clear on what it means.
Thanks again Sailor.
SailorSat:
doublescan is a modeline flag, just like -hsync or interlace.
it simply means that each line is output TWICE.
i.e. 320x240 is output as 320x480.
Ummon:
I've had some other computer trouble in the last day. One I got fixed, another I have no idea on, but before them, I had stopped some win services with idea of freeing up memory and such and now when I click on any version of soft15 I get a "runtime error '5' invalid procedure call or argument". Do you know what could be the issue here, SS?
bent98:
I sent an email to the omega driver team in hopes they can hack the 3000 byte buffer limitation on the forceware drivers. I really would like to fiddle with the usermodes.txt feature.
SailorSat:
--- Quote from: Ummon on February 06, 2008, 05:50:52 pm ---I've had some other computer trouble in the last day. One I got fixed, another I have no idea on, but before them, I had stopped some win services with idea of freeing up memory and such and now when I click on any version of soft15 I get a "runtime error '5' invalid procedure call or argument". Do you know what could be the issue here, SS?
Err... Okay ^^,
I'm pretty clueless on that one.
Go to full version
