Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
Dr.Venom:
Hi SailorSat,
We PM'd some time ago on the EAB board, about using Soft15Khz in a dual card setup. I recently purchased a new card, which is set in the primary GFX card slot, but unfortunately it takes 6 entries in the Soft15Khz menu, crowding out completely my HD4850 in the second gfx card slot :(.
See the image below:
Would it be possible to have the number of possible entries in Soft15Khz enlarged a bit, or maybe have the first 4 entries (vga framebuf etc.) moved to the end of the listing (like you used to have in earlier versions)? That way the HD4850 would show again. Any help with this would be greatly appreciated.
Best regards
adder:
--- Quote from: Dr.Venom on October 19, 2012, 06:53:06 am ---it takes 6 entries in the Soft15Khz menu, crowding out completely my HD4850 in the second gfx card slot :(
try clicking on one of the visible entries, and then using the down arrow key on your keyboard to move down to one of the entries which is not in view
SailorSat:
That's a rather creative idea :) Might even work!
Guess I'll "shortem" the menu to a simple dropdown.
Dr.Venom:
--- Quote from: jadder on October 19, 2012, 07:24:23 am ---
Thanks for the suggestion, but unfortunately it doesn't work. Moving down with the arrow key simply wraps at the last 7800 entry back to the first one.
--- Quote from: SailorSat on October 19, 2012, 08:31:50 am ---Guess I'll "shortem" the menu to a simple dropdown.
That would be perfect :)
Jack Burton:
--- Quote from: SailorSat on October 17, 2012, 10:18:20 am ---Modeline "1024x768@100" 126.64 1024 1056 1536 1568 768 781 794 807
Thank you, however it looks like this one is way too narrow to fit my monitor even with the horizontal size maxed.
Is there anyway I can just install a few resolutions with Soft 15khz and keep most of the ones my graphics card uses? If I use the customusers.txt option it causes all manner of issues.
Is there a way to copy the modelines my graphics cards usually uses?
