Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
SailorSat:
I would have guessed. HD5000 and HD6000 don't work at all. Most likely the same "safe mode" ---steaming pile of meadow muffin--- that nvidia introduced...
Arnold101:
:(...so you can't do nothing? i've tried with powerstrip too and same result
abispac:
Hi,
i have amotherboardwith a GMA3150 built-in.
I would like to put this MB in my CAB, with XP with Soft-15hz.
I think I understood that GMA processors are not fully supported and that only 5 resolutions can be used.
Does any gma processor are supported?Which are the 5 resolution that can be used? and how do i add them?
I wil be using hyperspin so i guess i need 640x480 or 800x600
neogeo games
cps2 games
and pacman ,galaga,and donkeykong wich i think they should be the same resolution.
many thanks for your futures answers!
kamranijaz:
--- Quote from: SailorSat on April 14, 2012, 07:19:52 pm ---I would have guessed. HD5000 and HD6000 don't work at all. Most likely the same "safe mode" ---steaming pile of meadow muffin--- that nvidia introduced...
Hi SailorSat,
I am really new in arcade machine setups and so, i just bought sega naomi universal cab and upgrading the existing system in it which is quite old with ipac setup in it, I have bought new Q6600 processor and the HD4650 as you mentioned in your card compatibility list and installed windows 7 64bit. my monitor is nanao with toshiba tube only output 31khz.
my question is if i install the lower resolution will they work properly on that arcade monitor or they will do some harm to the monitor screen. or i need to stick with 31khz mode only. as i need to play different emulators like demul, supermodel3 etc which requires high end graphics card than the processor power.
thanks
SailorSat:
Hm... Depends on the screen. If it is a 31kHz screen you most likely will see garbage on screen - and should not run it that way for too long.
