Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
Pages: << < (452/485) > >>
M3d10n:
--- Quote from: SailorSat on January 29, 2012, 01:37:52 pm ---@M3d10n:
Do ALL of the lower res modes behave like that?
No, the resolution used by CPS and CPS2 games seems to work flawlessly. It fooled me into thinking everything was working, because those were the first I tried. It was only when trying to run NeoGeo games that things broke down.
BTW, I'm using CabMAME 0.141.
Also, seems only the width causes the problem. Resolutions like 512x240 and 640x240 work normally (but they don't solve my problems because CabMame doesn't seem to allow non-uniform scaling).
karnov64:
sailorsat when u compile cabmame32ui 145 (as promised :lol) could you PLZ add the frogger/galaxian fix (frogger.diff) as i dont know how to compile myself :(
(ps. sorry i have to ask cabmame questions here but when i try to join the official cabmame forum (http://community.arcadeinfo.de) it wont seem to allow/confirm/add my new forum user account, so i cannot join)
SailorSat:
Consider it done.
Will upload the binaries later.
karnov64:
--- Quote from: SailorSat on February 10, 2012, 02:16:01 pm ---Consider it done.
thanku so much, i love cabmame :lol
ps. maybe you can tell me what line i add to MAME.INI to enable the frogger.diff hack? (or is is supposed to work automatically by default?)
i am having trouble and am wondering if frogger.diff is working ok? (note. im using directdraw and cabmameui32) .. i can provide my mame.ini or any other files if u like (here is my basic setup below):
81ramirez:
Would an 24c512 eeprom be suitable to use in a Edid dongle?
Thanks.
EDIT:
Or better yet, would a 24lc02b work? Would it need any modification?
Thanks.
EDIT2:
Looking ate this image, I can see that you are using an 24lc02b.
How do I wire it? Using an 24lc22a it would be:
VGA Pins 1, 2, 3, 5, 6, 7, 8, 9, 10, 13 and 14 are wired from the male to the female connector.
VGA Pins 5, 9, 11, 12 and 14 are wired to the 24LC22A.
or??
VGA 14 (VSync) -> IC 7 (VCLK)
VGA 15 (SCL) -> IC 6 (SCL)
VGA 12 (SDA) -> IC 5 (SDA)
VGA 09 (+5V) -> IC 8 (Vcc)
VGA 05 (GND) -> IC 4 (Vss)
I don't know which one is right and anyway, the 24lc02b have a WT instead of VCLK... what do I have to change?
Thanks.
Go to full version
