Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
SailorSat:
Hm... Laptop as primary won't work for sure.
But I don't have a clue atm.
vib_ribbon:
what is strange is that i tried making the arcade monitor the primary screen at 320x240, but it wouldn't accept it. seems like it doesn't like being the primary screen at all at any resolution. i also tried pulling out the 31khz jumper on the jpac, no luck at various resolutions. :'(
vib_ribbon:
--- Quote from: SailorSat on June 02, 2011, 04:43:05 am ---
As you can acutally see ONE screen currently, I don't think you need a dongle.
i found the latest driver and installed that, didn't help, in fact it has removed all the lower res options. looks like i might have to revert back to the previous.
i noticed you mentioned ONE screen. when i click on the identify button, it actually shows that there the image on the arcade monitor is split into 2. is that what you were referring to?
many thanks for your assistance.
Gray_Area:
--- Quote from: vib_ribbon on June 06, 2011, 01:02:18 pm ---
No. That means display number two is being displayed. The split screen is the JPAC allowing a non-15khz mode on your monitor.
SuprSprint:
Anyone had any success with the ATI All-in-wonder board PN 109-52900-03? It's labeled as a Rage 128, has one chip marked with AIW128, and has VGA, composite+L&R in/out, and cable TV interfaces. Soft15Khz sees it but won't install. I have what I believe are the latest drivers released for this card (2002).
It works fine at 15khz under Dos/TSR and AdvMame. But I'd like to upgrade from AdvMenu to GameEx front end, and that means Windows.
