Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
bent98:
I just got off the phone with billbas tech support and they said there were some reports of people burning out the horizontal at high refresh rates, so I was advised not to run above 90khz
SailorSat:
Hm... I've used both a GeForce6 and a GeForce7 without problems 15kHz "only".
I'm wondering why you get double vertical refresh with some resolutions without feeding some special modelines in.
P.S. Its Hz in vertical, not kHz :)
bent98:
Is there any suggestions or further tests you want me to preform?
SailorSat:
Hm... Take a look in the forceware, there should be a tab with costum resolutions, the should all be around 60Hz.
bent98:
They all say 60hz reported by OS and progressive, however 240x240 shows 58.80hz for example. Should I adjust anything?
