Main > Monitor/Video Forum
Soft-15KHz - slim new tool for 15KHz on normal vga cards
Pages: << < (40/485) > >>
bent98:
Ah ok I just tried it with just soundsync and emuspeed and it worked with u4. What the neogeo.diff? is that to address sound in neogeo games? Also Volume seems lower any way to adjust?
SailorSat:
neogeo.diff reenables the "real" 320x224 pixels the neogeo hardware does instead of the mame enforced 304x224.
Most games display some kind of "garbage" in those area, however, thats what the real hardware does.
It also kills some "scaling" errors.
TheManuel:
--- Quote ---If you want a real SMOOTH emulation you would want to disable throttle, frameskip and autoframeskip (throttle 0, frameskip 0 and autoframeskip 0).
Please note that you get sound disortions in the newer MAME builds, so consider giving "cabMAME" a try.
Hi SailorSat.
The sound distortion you are referring to here, is that the fact that if you are synchronizing the framerate to a monitor refresh rate that is different from the original game's you get a different sound pitch?
SailorSat:
you SHOULD, however mame doesn't change the pitch so if doesn't generate enough samples if the emulation is lower than 100%, and you get too many samples if it's faster than 100%.
TheManuel:
So what is the sound problem that cabmame addresses?
Go to full version
