Main > Main Forum
mortal kombat 1 resolution help required
DeLuSioNal29:
--- Quote from: ahofle on April 09, 2008, 12:33:33 pm ---
--- Quote from: DeLuSioNal29 on April 09, 2008, 12:23:59 pm ---Uninstalling the drivers helped. For good measure I ran a free utility from ATI that completely removes all remnants of the drivers on your system.
Do you have a URL for that utility? I went ahead and ordered an ATI 9800 Pro off ebay for $50 (which is apparently on the Soft15khz checklist), but it would be nice to know if this is a card or driver issue with Soft15khz.
Sure thing. Here you go: http://downloads.guru3d.com/download.php?det=1275
The file is hosted by guru3d.com but the utility was created by ATI.
~ DeLuSioNaL
Zebidee:
That Catalyst uninstaller program is good - it ensures a blank slate on which to do a fresh install. I've used it in the past to get around AVGA driver problems, but I've never seen this one, with resolutions missing. But then, I've always used AGP versions of the AVGA2 cards, which use the ATI 9250 chipset, and other ATI 9250 chipset based video cards. The missing resolutions may be a new problem specific to the ATI9550/9600 chipset series.
I'll try it on my ATI / soft15khz setup when I get the chance.
Thanks, Zeb.
ahofle:
I tried the uninstaller tool, but the lame line-doubled resolutions are still there after a fresh install. I think they must be part of the 9600XT I have. :badmood:
DeLuSioNal29:
--- Quote from: ahofle on April 09, 2008, 09:18:46 pm ---I tried the uninstaller tool, but the lame line-doubled resolutions are still there after a fresh install. I think they must be part of the 9600XT I have. :badmood:
There is a program called "Refresh Force" that allows you to remove resolutions. It's recommended by Retroblast. See the article here (and the link to download): http://retroblast.arcadecontrols.com/articles/monitor2.html
I've never used it so I can't vouch for it. But it looks like it may solve your problem.
~ DeLuSioNaL
ahofle:
--- Quote from: Zebidee on April 09, 2008, 08:12:05 am ---Ahofle - I have exactly the same situation with my setup using Soft15khz on an ASUS A9550 videocard (ATI chipset). Curious.
Just an FYI, it appears that SailorSat (the author of Soft15khz) now has a card with this same problem and is going to look into a fix:
http://forum.arcadecontrols.com/index.php?topic=66402.msg823238#msg823238
