Main > Main Forum
time soldiers arcade help
Pik4chu:
--- Quote from: CheffoJeffo on May 05, 2007, 08:55:07 am ---If you crank up the brightness, do you see raster on the monitor ?
How many beeps are you hearing ? do the tones change ?
Cheers.
it is 4 beeps, the first beep is a bit lower pitched than the rest and the last 3 beeps are high pitched and happen really fast. As for the brightness I'm pretty sure it is turned all the way up (all the way to the right?) but the notes on the label dont say anything about brightness the only ones that might help are called "monitor" and "focus" the label also seems to denote the monitor type as 69X1008-100, but messing with either of the two nobs I mentioned above does not change anything.
And some bastard sniped me on the replacement sticks :angry: :angry:
MaximRecoil:
--- Quote from: Pik4chu on May 05, 2007, 02:26:20 pm ---
Thank the alchemist at videoconnect.com for that. He single-handedly turned $10 (NOS) joysticks into $80 (NOS) joysticks, and the old beat up LS-30's kicking around, the same ones you used to be able to get already mounted in an Ikari Warriors or whatever CP for like $15 (including the CP), instantly followed suit.
Pik4chu:
--- Quote from: MaximRecoil on May 05, 2007, 04:11:47 pm ---
well the game board got sniped as well, even worse than the sticks. 4 seconds left.. #$^*)#@*@!@#^*& So I guess now all I care about is if the monitor is toast as well and if so how hard is it to fix.. -_-
