Author Topic: Attaching Leland Spring Joysticks  (Read 952 times)
campbelldave
  • Last login:March 11, 2016, 07:48:48 am
« on: May 01, 2007, 10:31:40 pm »
I just won a pair of analog spring joysticks on eBay from a World Series control panel.
What is the easiest way to attach them to a PC for MAME?
Is there an interface that they would plug into directly?  I would prefer not to cut up and splice the wires, if I can avoid it.
Thanks for your help in advance!
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Attaching Leland Spring Joysticks
« Reply #1 on: May 02, 2007, 01:07:00 am »
The three most common methods to hook up an analog joystick (which is what those are):
Ultimarc A-Pac (either variety)
Dave's AKI
Dual Strike Hack
campbelldave
« Reply #2 on: May 02, 2007, 06:54:52 am »
Thanks Kremmit, I will look at each and give one a shot
Justin Z
  • Last login:March 15, 2024, 10:53:05 am
« Reply #3 on: May 02, 2007, 10:18:03 am »
This may help.
http://dave.bit2000.com/aki.html
These connect to the 5k pots on the stick and then interface via USB.  They can support two of the sticks (or a stick and 270° driving controls, etc.) and also have button inputs.
campbelldave
« Reply #4 on: May 02, 2007, 04:11:03 pm »
This looks pretty simple.  I will order one and then post a message on how it turned out.
Kremmit
  • - AHOTW -
« Reply #5 on: May 03, 2007, 01:30:58 am »
Oops!  Thanks Justin, that's the link that I appear to have screwed up above.   :cheers:
