Main > Main Forum
Sources for lighted pushbuttons
Kaytrim:
--- Quote from: HooPZ on May 02, 2007, 12:35:50 pm ---
--- Quote from: Kaytrim on May 02, 2007, 12:33:36 pm ---
--- Quote from: HooPZ on May 02, 2007, 12:28:35 pm ---I am using the LEDwiz to power 14 buttons and it's connected via USB. Should I have the 5v line connected to the LEDwiz? It's been this way since early March and I haven't had any problems. At least, not yet... :)
Are you using the NovaGems or the button blaster LEDs? If you are using the Button Blasters then you are fine.
14 x 20 = 280ma, well below the 500ma that you can get via USB.
Sorry, I am using the NovaGems.
If I were you I'd get an external 5v source on your LEDWiz. If you max out all the NovaGems you are looking at 1400ma nearly triple what USB can supply.
RandyT:
Yes, get the external 5v line hooked up. The implementation will vary, and I've heard that some USB ports are fused for as much as 2 amps (surge.) And of course, if all of the buttons are not on at full power at the same time, then the requirements would be lower. But it's good to play it safe.
RandyT
Hoopz:
I'm on it! Thanks Kaytrim and RandyT. :cheers:
GAtekwriter:
The sheer amount of free tech support I've seen from Randy has convinced me :) NovaGems it is!
Jim
Cornchip:
Wikpedia has a good section about USB and the current that it can supply.
http://en.wikipedia.org/wiki/USB
Cornchip.
