Main > Main Forum
I got outbid :(...
Pages: << < (5/5)
shardian:
--- Quote from: knave on May 02, 2007, 02:25:24 pm ---Cool site but I couldn't get it to work all the way.  I would choose my cities, enter a search, and the catagory and when I hit search all that could come up is the front pages of the CL in the cities I chose.  It would not run the search...
...Anyone else?
Same here.
Kaytrim:
...Anyone else?
I can't get it to work either.  I even tried areas where I knew that there should be a few cabs.  Then I was looking on the site and I found the following information...
GOOD NEWS, NO MORE CRAIGSLIST HOMEPAGES FOR RESULTS!!
learn more ->
if you're using the excellent web developer firefox extension then simply go to the disable menu and "Disable Referrers". if you don't have that extension you can go to the location bar in firefox and type "about:config" and hit return. there will be a window with a bunch of stuff, in the filter field type "sendrefer" this will reduce the big list to network.http.sendRefererHeader. click on that row, and change the 2 to 1 or 0 (1 will send the referrer to a site when you click on a link only, 0 will not send any referrer information -- thanks to brian for the about:config tip!). If you're using Opera you can alter this setting as well. in the location bar in type "opera:config", then type "referrer" in the search box, uncheck the enable referrer setting, and search like a madman! If you're using IE, delete it and use anything else ;)
Havok:
--- Quote from: ChadTower on May 02, 2007, 10:35:32 am ---
Where is the RSS feed?  I have looked for one but couldn't find one.
Just do a search for whatever parameters you are looking for, and scroll down. In the lower right corner, there is a RSS text highlighted. Right-click on that, select copy shortcut, and paste into your favorite RSS reader...
ChadTower:
Obscure, but it works.  Thanks!
Nostalgia:
...Anyone else?
Try it with Firefox, It works great. Or read at the top about the issue with IE.
Pages: << < (5/5)
Go to full version
