Author Topic: Understanding Shazaaam Button  (Read 1370 times)
Squeeky
  • Last login:February 17, 2012, 04:10:56 pm
    • Makre $220 for Free, Follow My Tutorial
« on: April 30, 2007, 02:11:20 pm »
Ok I read through past post and it got me even more confused.  I recently purchased a KeyWiz Max, and I'm attempting to understand the shazaaam button.  Essentially I want to use this as my admin funtions.
Can I do the following:
Wire Pause Pushbutton for both pause and shazaam,
Then withing the software asign pause + P1 = Esc
pause + P2 = Esc
pause + P1 Coin = admin button
Pause + P2 Coin = admin button
etc.
This way the only "admin" button on my CP is pause
Also could I take it a step further and make P1 coin shazaam and then address a combo for pause as well?
I want to keep the button layout simple, but not lose any admin features.  Also thought that would be better then Esc key that might accidently get hit.
Kaytrim
  • I'm too nice a guy
Re: Understanding Shazaaam Button
« Reply #1 on: April 30, 2007, 04:17:47 pm »
It is discouraged to have a dual purpose button on your CP.   If you were to have one button be both Pause and Shazam the game would flicker between paused and unpaused states while you held down the button for the Shazam functionality.  The topic has been hashed and rehashed several time in the few months that I have been around these forums.  If you want to use the Shazam functionality of the KeyWiz I suggest that you mount a button on the underside of your CP where it can be easily reached but out of sight.  Other wise have the minimum of admin buttons on the CP, pause & quit as well as a dedicated Shazam button.
TTFN :cheers:
Kaytrim
RandyT
  • Last login:Yesterday at 11:46:17 am
    • GroovyGameGear.com
« Reply #2 on: April 30, 2007, 04:29:14 pm »
You can also have the "only Admin button on your panel" be the Shazaaam! button.  Just use the Shazaaam! button plus;
Player 1 Button 1 for Enter
Player 1 Button 2 for Settings
Player 1 Button 4 for Exit
Player 1 Button 5 for Pause
...etc.
This is based on the defaults settings, and is part of the reason these definitions were included in the default set.
RandyT
Squeeky
« Reply #3 on: April 30, 2007, 07:10:03 pm »
RandyT,
So you recommendation would be the wire P1 as the shazaam key?
Then the other comment is to use a dedicated button for shazaam.
Any other comments before I order my buttons.
NoOne=NBA=
« Reply #4 on: April 30, 2007, 07:17:28 pm »
That's only true for the KeyWiz.
The single pause/shift button works fine on the Ipac because it's shift function works differently.
Tiger-Heli has a nice page about the shift functions HERE.
He doesn't address the pause/shift configuration of the Ipac though, which is my preferred configuration of ANY encoder.
If you remap the Ipac so that the Pause button is also the Shift button, and all the admin functions are mapped to P1 buttons, it makes it very difficult to accidentally hit admin functions.
SavannahLion
« Reply #5 on: April 30, 2007, 07:26:17 pm »
RandyT,
No, he's saying the Shazaam key has its own dedicated button.
Squeeky
« Reply #6 on: April 30, 2007, 07:32:36 pm »
Ok I'm going to wire the shazaam button dedicated, figure I will hide in the upper left hand side of the CP.  I'll assign the admin keys to shazaam, and P1, Coin1, Left Click.  Assume I follow Keneivel's CP design.
NoOne=NBA=
« Reply #7 on: April 30, 2007, 10:15:58 pm »
I would put all the admin functions on P1's player buttons.
That way they are all together, and you can make some sensible arrangement out of them.
I'm not sure what you mean by Left Click either.
If you mean Left on the joystick, that won't work.
The joystick will switch codesets when pressed left/right in shazaam mode.
