Author Topic: Timoe's Mini Sticks  (Read 78333 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Timoe's Mini Sticks
« on: April 25, 2007, 08:03:58 pm »
Uh oh!   What are these??!!
The sides and back are 3/4" mdf (2 pieces laminated together)
The top is 5/8" mdf
The bottom is 1/4" mdf plexiglass
I'm just waiting for the glue to dry then I'm going to flush trim the pieces and route a 45 degree chamfer around the edges of the laminated pieces.
« Last Edit: September 10, 2008, 09:22:45 am by Timoe »
Knievel
    • Knievel Kustoms
Re: Timoe's Mini Styx
« Reply #1 on: April 25, 2007, 09:29:06 pm »
Cookbook holders?
  • Last login:November 30, 2025, 12:59:41 am
« Reply #2 on: April 25, 2007, 09:48:50 pm »
Styx eh?
Domo arigato, Mr. Roboto,
Mata ah-oo hima de
Himitsu wo shiri tai
Donkey_Kong
    • CNC Machines
« Reply #3 on: April 25, 2007, 10:07:48 pm »
Thank you very much, Mr. Roboto
For doing the jobs that nobody wants to
   :laugh2:
« Last Edit: April 25, 2007, 10:10:31 pm by Donkey_Kong »
theCoder
« Reply #4 on: April 25, 2007, 10:27:14 pm »
Let's see.... A soldering iron and hacked game controller in the background?  I'm thinking dual level spice rack for the wife.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #5 on: April 25, 2007, 11:41:27 pm »
Thats funny.  I guess I could make a spice rack that looks like a game controller/cook book holder.
I really have no idea why I'm even making these.   :dizzy:  If someone reading this decides that they want them, they will certainly be available.
I should have taken a shot to show the scale, they are pretty small.  The CPT is smaller than 8x11.  I'm thinking I'll make one white and one black.
« Last Edit: May 12, 2007, 10:01:06 pm by Timoe »
waldo
  • Last login:November 05, 2008, 01:44:00 am
« Reply #6 on: April 25, 2007, 11:42:40 pm »
Im thinking they will be used for pillocking
the mud sport where you skip across mud flats on wooden shoes
blueznl
« Reply #7 on: April 26, 2007, 05:25:48 pm »
Props for a home brew Star Trek episode?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #8 on: April 26, 2007, 08:52:52 pm »
I dont know why but I decided to use glue and dowels to hold the case together.  I guess I just didnt want to use putty and deal with all that sanding to cover screw holes.
The cases fit together pretty tight.  I'm going to wait and see if I come up with any more ideas before I glue em together.
The top panel is held down a little less than 1/8" from the top of the side to allow for a plexiglass cover over the CP.
« Last Edit: April 26, 2007, 09:01:39 pm by Timoe »
shorthair
« Reply #9 on: April 28, 2007, 01:30:02 am »
Yeah, I immediately thought mini-panels.
danny_galaga
  • Last login:Yesterday at 06:37:38 am
    • dans cocktail lounge
« Reply #10 on: April 28, 2007, 05:32:19 am »
im thinking more along the lines of blakes 7, or doctor who  ;D
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #11 on: April 28, 2007, 09:02:38 am »
Maybe for the sequel of Redemption 101?
psychotech
    • psychotech
« Reply #12 on: April 28, 2007, 08:38:28 pm »
They look good, whatever they are..  :)
Still, I'm sure we all need MORE PICS!
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #13 on: April 28, 2007, 11:38:38 pm »
I gotchyer Pics-
I thought it would be cool to use the roundover bit on the cable hole in the back.  I used it on both sides just to make it look smooth.   I think I saw theCoder do it once.
 Here is a before and after pic.
« Last Edit: April 28, 2007, 11:50:26 pm by Timoe »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #14 on: April 28, 2007, 11:41:13 pm »
I read in a recent ShopNotes magazine that it is good to smooth out the endgrain of mdf with drywall mud if you are going to be painting it.  I had some 20minute mud that I snatched from a jobsite and so here we are.
I had an imperfection in one of the pieces due to bad math so this should fix that end piece.
« Last Edit: April 28, 2007, 11:50:58 pm by Timoe »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #15 on: April 28, 2007, 11:49:01 pm »
I have always wanted to try those Japanese style joysticks and buttons.  Thats really why I am making these things.  I am modeling them after the Byrdo.org style cases.
So far, every control panel I have made has had the top of the CP open or removable.  Its just how I've always done it.  This time the construction will be more like a commercial joystick where the wiring is accessed through the bottom.
I will have 4 screws that go through the rubber feet into the four corners of the bottom of the box.  The control panel top will be permanently attached to the box.
For this reason I decided to use hardwood in the four corners as opposed to mdf.  Mdf just comes apart too easily if you are taking screws in and out of it all the time to access the insides.
In this pic you can see how I have clamped and glued the hardwood pieces to the mdf.  The corner pieces have a matching 2 degree slope to maintain the angle and the support.
« Last Edit: April 28, 2007, 11:52:15 pm by Timoe »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #16 on: April 29, 2007, 01:41:44 am »
I used 1/4" dowels on the front piece and 3/8" dowels on the back piece.
The drill press makes it real nice to drill plumb into the side of the mdf.
Knievel
    • Knievel Kustoms
« Reply #17 on: April 29, 2007, 11:18:56 am »
Think you just set some sort of record for #of clamps used on a piece this size. ;D
Drywall mud works great for sealing end grain. Bondo Spot Putty(the red stuff in a tube) works great too and dries fast. I've been using it instead of wood filler for some time now.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #18 on: April 29, 2007, 02:10:47 pm »
Yeah I used a lot of glue and clamps, but they're solid.
A little more mud and sanding and they'll  be ready for primer.
« Reply #19 on: April 29, 2007, 04:05:31 pm »
Some serious woodworking going on here - looks great.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #20 on: April 29, 2007, 07:09:55 pm »
Spray paint is so smooth.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #21 on: April 29, 2007, 11:35:06 pm »
Here is another gratuitous pic showing the smoothness of spray paint.
I used a gloss rustoleum.
1. Do you think I should use a few coats of glossy clear coat?  Any recommendations for product? Spray on, etc?
Also, now I'm looking for artwork.  In keeping with the japanese theme I imagine some anime artwork if not street fighter style.
2.  Any recommendations of desktop wallpaper or artwork websites?
shorthair
« Reply #22 on: April 30, 2007, 01:19:14 am »
Ohhhhh...styx/sticks.  I thought something literary-themed from that name.
theCoder
« Reply #23 on: April 30, 2007, 01:48:20 am »
What ever you do, I would not recommend 8 color coats followed by 5 clear coat.  Way too much.  I'd definitely go with one or two coats of a clear lacquer.  I used stuff in a spray can.  Just make sure to hit it with steel wool or 600+ grit paper between coats.
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #24 on: April 30, 2007, 07:30:21 am »
Nice work so far Tim, I'm guessing one of these is going to be your Ms Pacman right?  What is the other one going to be?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #25 on: April 30, 2007, 08:59:15 am »
Yeah I dont want to put any more work into these things than I have to, they're sort of a side project right now.  I've always wanted to try the spray on poly.  We'll give it a go.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #26 on: April 30, 2007, 09:00:52 am »
Actually I havent started on our panels yet.  I'm actually at the wiring/troubleshooting stage with another project right now and I was just working on these little guys in my off time.
vrf
  • Last login:October 13, 2017, 10:11:54 pm
    • Pixelbox
« Reply #27 on: April 30, 2007, 10:34:47 am »
Great technique with the Bondo-patched MDF and a quality paint job. Looks almost like real wood, especially with the beveled sides instead of t-molding. It'd be cool to see that style on a little bartop cab.
Great work!
stephenp1983
« Reply #28 on: April 30, 2007, 06:53:27 pm »
What are you working on now?  Did you ever finish that big steering wheel thing you did after mine.  I kinda lost track of it.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #29 on: May 02, 2007, 08:40:17 pm »
The guy is coming to pick it up right now.
I'm still learnin how to use spray paint.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #30 on: May 04, 2007, 09:14:44 pm »
We're going to use Sanwa JLF joysticks in these little guys.  Thank you Ponyboy for the fast service.
These JLF sticks are sure different.  The joy itself is tiny but it has all these odd shapes jutting out of it.  I want to mount it flush with the surface of the control panel and then cover it with plexi.
« Last Edit: May 20, 2007, 02:18:51 pm by Timoe »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #31 on: May 04, 2007, 09:15:17 pm »
« Last Edit: May 20, 2007, 02:20:17 pm by Timoe »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #32 on: May 04, 2007, 09:15:44 pm »
On the Sanwa JLF stick there are these weird little plastic pieces jutting out just under the mounting plate.
« Last Edit: May 20, 2007, 02:20:58 pm by Timoe »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #33 on: May 04, 2007, 09:16:10 pm »
Step three:
The JLF features a nice wire plug to make it look all tidy, but it juts out at the bottom and the 5/8" mdf is too thick for it to sit properly.
Here is the notch I cleared out for the wiring harness.
« Last Edit: May 20, 2007, 02:21:34 pm by Timoe »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #34 on: May 04, 2007, 09:17:00 pm »
For fun I added some button holes & buttons.
« Last Edit: May 04, 2007, 09:29:19 pm by Timoe »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #35 on: May 05, 2007, 04:31:09 am »
Looks pretty neat and tidy with all those templates.
BTW Love the dovetails!
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #36 on: May 05, 2007, 08:53:23 am »
Nice job on the sanwa mounting templates. :cheers:
I use a similar system but only use two templates.
It's 9am. I'm calling it a nite.
Aurich
  • Last login:September 12, 2021, 01:34:32 am
Re: Timoe's Sanwa JLF Mini Sticks
« Reply #37 on: May 05, 2007, 12:26:12 pm »
Sanwa snap ins are so satisfying after threading those long ass Happ buttons. :)
Did you get some .110 QD for the buttons?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #38 on: May 05, 2007, 09:14:47 pm »
No I didnt, I was contemplating solder cause it can make the wires look so tidy.  But I like the idea of keeping the parts in pristine condition.
Any suggestions on where to get the tiny QD's?  Home depot, auto parts store, etc?
NiteWalker
« Reply #39 on: May 05, 2007, 09:18:05 pm »
I get em here. They're excellent quality and the fit is very tight. They won't fall off. On sanwa applications I highly recommend quick disconnects for replacing the buttons as they don't last as long as Happ buttons.
