Author Topic: Terminal Blocks  (Read 1326 times)
markt
  • Last login:May 08, 2010, 07:48:50 pm
Terminal Blocks
« on: April 24, 2007, 08:35:27 pm »
There was a thread somewhere that had a picture of this terminal block.
Someone had asked where to get them.
I found them at Lowes home improvement, in the electrical dept with the wiring terminals.
bfauska
  • Last login:May 06, 2024, 02:41:27 pm
Re: Terminal Blocks
« Reply #1 on: April 24, 2007, 10:22:10 pm »
Somebody asked about them in my project thread, I don't know if that is where you saw it or not, but I responded that you can get them from Groovy Game Gear.  I will say however that the ones I got from GGG had some stripped screws in them so I had to be creative with their use.  The terminal strips and crimps were the only things I had any issues with from GGG, but they were really inexpensive and I made them work so I didn't mind.  I imagine that the ones from Lowes are a fairly nice terminal strip, I have been happy with all my products from Ideal.  I bet it cost a little more than Randy's though.
Crowquill
  • Last login:December 03, 2021, 05:02:15 pm
Re: Terminal Blocks
« Reply #2 on: April 25, 2007, 02:05:48 am »
They aren't that rare. Radio Shack always has them. I think they classify them as a "European Style" terminal strips.
I thought these would be better over the traditional terminal strips, but if when using wire that's smaller than 20ga I had a harder time getting the wires pinned under the screw. It can be done by doubling up the wire, but the standard strips still are easier. I also had problems with screws stripping and I think a lot of it has to do with the soft nylon that these are made of. In the end I decided to stick to the old stand-bys:
Re: Terminal Blocks
« Reply #3 on: April 25, 2007, 09:24:13 am »
I've used a lot of Ideal's stuff... it's good for light use, but if you're going to be using things a lot, like an RJ45 wall jack that gets cycled a lot, go with something better.
Level42
Re: Terminal Blocks
« Reply #4 on: April 25, 2007, 02:54:32 pm »
Haha, these things can be bought here on every streetcorner....they are intended for mains wiring. F.I. house installations here have non-stranded wires that come into a box (usualy in new homes set in the concrete). Than you get two or three terminals of a strip like that and wire up your light armature to it. Remeber that if you use stranded wire to tin them for best contact.
They used to be called "kroonsteen" )= "crownstone") here and most people still call them that way.....stange name....:D
They used to look more like this:
Personlay I use a pretty fancy terminal strip, mainly because sometimes these are "left over" from some work projects.
It's a mini-DIN rail. This one simply has only terminals on it. I only use this for power distribution now, although not much is connected to it yet :D
« Last Edit: April 25, 2007, 03:00:42 pm by Level42 »
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
Re: Terminal Blocks
« Reply #5 on: April 26, 2007, 12:27:36 am »
I get em all right here. So far the cheapest I've found. This was a while ago but I bought 20 and the shipping was only $3.95.
It's 9am. I'm calling it a nite.
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
Re: Terminal Blocks
« Reply #6 on: April 26, 2007, 01:05:55 am »
I have used these to wire up AC to monitors and flourescent light fixtures in my cabinets.  Also good for speakers and anywhere you would use a molex connector.
They are great, just cut off two or three terminals at a time and use them like a
"Lazy man's molex connector".
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
