Author Topic: Neo Geo Bios rom change  (Read 6331 times)
BobA
  • What Me Worry?
« on: April 18, 2007, 01:25:03 am »
Mame32 allows you to select between US and Japan ROMS but not the others in the ZIP.    How do you use the UNIbios roms that are included in the NeoGeo BIOS zip?    Do you overwrite the US BIOS rom and if so which one?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Neo Geo Bios rom change
« Reply #1 on: April 18, 2007, 12:29:57 pm »
Not sure why mame32 isn't letting choose the other bios.  Quote from windows.txt in the docs folder:
-bios <biosname>
   Specifies the specific BIOS to use with the current game, for game
   systems that make use of a BIOS. The -listxml output will list all of
   the possible BIOS names for a game. The default is 'default'.
And a clip from the first neogeo game in listxml:
Code: [Select]
<game name="nam1975" sourcefile="neogeo.c" romof="neogeo">
<biosset name="euro" description="Europe MVS (Ver. 2)" default="yes"/>
<biosset name="euro-s1" description="Europe MVS (Ver. 1)"/>
<biosset name="us" description="US MVS (Ver. 2?)"/>
<biosset name="us-e" description="US MVS (Ver. 1)"/>
<biosset name="asia" description="Asia MVS (Ver. 3)"/>
<biosset name="japan" description="Japan MVS (Ver. 3)"/>
<biosset name="japan-s2" description="Japan MVS (Ver. 2)"/>
<biosset name="japan-s1" description="Japan MVS (Ver. 1)"/>
Looks like there should be eight choices for the bios, unless the game you're playing wasn't released in all regions.  What game(s) have you tried?
Might be a mame32 limit, anybody else help him here?  Can you type in the other valid bios (those in the list above)?
Not sure about the UNIbios, either.  I don't think official mame or mame32 will use it as it doesn't match the CRCs.  Maybe other derivatives have added support, though?
Not much help, sorry. :-\
Robin
Knowledge is Power
BobA
  • What Me Worry?
« Reply #2 on: April 18, 2007, 03:34:36 pm »
Thanks for the info.  The unibios would probably need some sort of derivative mame to run.   I get all the regular 8 choices but not any of the unibios versions.  The unibios versions are included in the neogeo.zip bios file so they must be intended for some sort of use.
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
« Reply #3 on: April 18, 2007, 05:41:29 pm »
You would have to use a Mame with support for the uni-bios. I compile my own and add support for it (That's if mame32+ hasn't updated their source). The uni-bios is commented out in offical Mame
If You Are Going To Meddle At Least Listen
BobA
  • What Me Worry?
« Reply #4 on: April 19, 2007, 08:22:45 am »
Thanks for that info.
SavannahLion
« Reply #5 on: April 23, 2007, 07:59:43 pm »
If I'm following this conversation right, the UniBIOS isn't enabled (included, supported, whatever) in MAME because it's a Homebrew project. Hence it, as it's been thrown at me on more than one ocassion, doesn't jive with MAME's goal of accurate emulation of the original hardware.
Or is this a completely different UniBIOS beign discussed?
I'm suprised Dion Dakis isn't all over this like a downtown whore looking for crack.
  • Last login:May 03, 2024, 11:58:33 pm
« Reply #6 on: April 26, 2007, 12:53:48 am »
Well that shouldn't be an issue... rom hacks are often included in mame and that is essentially what the unibios is... it was created to be put and has been put in real mvs machines.
