Author Topic: How do I assign buttons to my Ultimarc 360?  (Read 1120 times)
  • Last login:Yesterday at 07:54:28 pm
« on: April 17, 2007, 09:57:36 pm »
I'm using the wiring harness and under control panel -> gamepads it is recognized and I can tell that the buttons are also recognized.  How do I assign button 8 to ESC, button 4 to Player 1 Start (1), button 7 to Pause (P), etc.?  Also, my joystick is installed upside down so how do I change right to left, left to right, up to down and down to up?
THANKS!!
destructor
Re: How do I assign buttons to my Ultimarc 360?
« Reply #1 on: April 18, 2007, 02:48:58 am »
1. Enter in game to menu (hit TAB) and assign buttons.
2. Unscrew U360 PCB and rotate it.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #2 on: April 18, 2007, 09:24:20 am »
Note the PCB does have TOP marked on it.
Andy
« Reply #3 on: April 18, 2007, 09:37:03 am »
Thanks - I was hoping there was some magical solution.  Do I have to assign the buttons for every single game?  What a pain!
 :angry:
I love the stick so far though!
Havok
  • Trade Count: (+17)
« Reply #4 on: April 18, 2007, 11:00:12 am »
After hitting [Tab], select Input general, and it will set your assignments for all games...
« Reply #5 on: April 18, 2007, 04:14:07 pm »
Hmmm... I thought I tried that out last night and the settings didn't keep from one game to the next.  I'll give it another shot because that makes the most sense...
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #6 on: April 18, 2007, 05:19:57 pm »
Maybe you could just redo the U360 maps.  Then it would send a UP when it's actually being read as DOWN (while you are pushing up).
I'd think that the 'input general' would be just as easy.
Is there a reason you don't want to rotate the PCB to the correct orientation?  I'm guessing - wire routing?
If I do not respond to your post in a timely manner, feel free to PM me.
« Reply #7 on: April 18, 2007, 05:24:31 pm »
Nah, I'm going to flip the U360 the right way.  Everything is wired and I thought it would be a problem but then I remembered that I'm an idiot and the harness and USB cable are easliy unpluggable.  It shouldn't be a problem.  Now all I have to do is figure out how to configure the buttons.
rockin_rick
« Reply #8 on: April 18, 2007, 05:27:02 pm »
It may work fine as is (with proper config - I don't know I haven't gotten that far yet...), but if not, then maybe joy2key?
