Main > Main Forum
How many fans are you running out of you CAB?
SavannahLion:
--- Quote from: ChadTower on April 18, 2007, 09:20:05 am ---The best way is to have one fan near the top blowing out and one near the bottom blowing in.
I quit that design when my poor kitten got sucked up into the bottom fan with an experimental PC case. I got a beating from my ex that day. :scared
ChadTower:
How the hell does anything at all get sucked up into a 5v or 12v fan? They barely suck in dust. ???
meany:
Only one on the Bat-Cade
urbecrisch:
As of right now I think I'm going to leave the back open until I figure out what to do. I like unclet's idea about cutting some holes instead of powering fans. I can cut some holes in the removable back panel at a later date. I'll play around with the idea and see what works out best.
SavannahLion:
--- Quote from: ChadTower on April 19, 2007, 09:27:38 am ---How the hell does anything at all get sucked up into a 5v or 12v fan? They barely suck in dust. ???
I was fiddling around with water cooling at one point and, IIRC, I was using a 150mm fan for the cooling coils. Getting "sucked" up probably isn't an accurate description. I suspect she was screwing around with the blades that day. I didn't have the guard in place, so she simply got trapped between the blades and support pieces.
No trauma, she fell asleep inside the same PC the next day.
