Author Topic: Older Mame with newer roms compatibility  (Read 1461 times)
Tomodachi
  • Last login:April 27, 2007, 04:54:45 pm
« on: April 13, 2007, 12:39:35 pm »
I'm trying to find out if an older MAME version will run the newer MAME roms. For example: I have roms for version 114. Will those roms work on say MAME version 1.0, .98, .89. etc.?  Is there a cut off where it will work on some older MAME versions, but only to a certain point?
I have a spare PC (PIII, 500mhz) that I would like to use for MAME, but I think I'll need to run an older version of MAME for best performance. I only have roms for version 114. I'd like to be able to use these instead of hunting down older versions of these roms.
lokki
  • Last login:June 29, 2017, 12:57:48 pm
Re: Older Mame with newer roms compatibility
« Reply #1 on: April 13, 2007, 01:15:28 pm »
You should be able to use clrmame to downgrade your roms to work on a previous version.
http://www.clrmame.com/
Guide on how to use it
http://www.mameworld.net/easyemu/clrmameguide.htm
Tomodachi
« Reply #2 on: April 13, 2007, 01:23:26 pm »
Thanks alot! :applaud: :applaud: :applaud:
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: April 13, 2007, 02:34:55 pm »
Backup your 0.114 set first, though!!!
WLVRYN
  • Last login:December 15, 2008, 02:03:52 am
« Reply #4 on: April 13, 2007, 03:08:30 pm »
Would this work for Tempest?  I cant seem to get that ROM to work with MAME .111.  I guess there's a file missing in the ROM that I have, but I cant seem to find a ROM that has the entire file set or just the missing the file on its own.
Zeppo
  • Last login:February 14, 2024, 10:26:44 am
  • Greetings Program!
« Reply #5 on: April 14, 2007, 12:53:02 pm »
Good to know.
I haven't had much luck with clrmame in the past, but I have been wanting to try older mame versions, so I'll try again.
Thanks for the info.
Z
