Main > Everything Else
Boot XP from CD-Rom? Need help fellas...
<< < (5/5)
boykster:
--- Quote from: DrewKaree on April 16, 2007, 12:47:14 am ---When a drive fails in either system, how do you know it?  Does it throw an error, and is it the same regardless of hardware or software setup?
What Samstag said, but with a bit of elaboration:
Nearly every form of RAID (hardware or software, OS dependant or otherwise) has a mechanism for alerting the user that a failure has occured.  usually this is some form of monitoring application that either is just a nagging alert of some sort, or a more sophisticated process that can send an email, initiate a shutdown, etc.
I have 2 linux servers with 3ware hardware RAID cards that automatically shutdown after 5 minutes if an array becomes degraded. I also receive an email notifiying me of the degradataion and shutdown as well.  Additionally, 3ware provides a web based "console" that can be used to monitor the arrays, perform maintenance, etc.
I used to have a hardware/software RAID1 setup (on a dedicated card) on a workstation at work up until december.  There was a monitoring application that could be configured to do the same thing...popup alert of drive problem, shutdown the machine, etc.
Navigation
[0] Message Index
[*] Previous page
Go to full version
