Main > Main Forum
taking paint of plexi?
Pages: << < (2/2)
shardian:
Some strippers etch plastic. At Lowes, you can get some stuff called motsenbocker's Lift off spray paint remover. It is very mild, and does take paint off. It can take a little elbow grease, but is so safe you can do it without gloves.
struby:
alright, well that all sounds good, while my cp is together i'm pry gonna play it, and then maybe do a repaint in summer time and put in nicer bolts and put some better trim on, thanks everyone
bfauska:
--- Quote from: struby on April 10, 2007, 05:09:45 pm --- i'm pry gonna play it, and then maybe do a repaint in summer time and put in nicer bolts and put some better trim on
Famous last words. :laugh2:  I enjoy the building process more than playing usually , but I still have a hard time turning the game off long enough to get anything done.
struby:
haha, right now i have a 4p control panel, paint messed up on back of plexi, painted black, a trackball hole and mounter bracket for my betson, but no trackball in it, just sitting in my room, no box under, the cp is on two chairs, and a 21 inch computer monitor in front of it, i'll post pictures either here or in the cp thing first, it is also running off my every day desktop pc, and i have a mouse and keyboard in the middle of the thing, also missing a 4th joystick at the moment because the one i ordered when i broke one doesn't quite fit, the three admin buttons are hooked up to nothing, hense the need for a keyboard, and p3 coin does not usually function and p1 and p4 start are a little slow, and also p3 joystick only has 3 bolts in it cuz one would run into my trackball mount so i have to fix that, BUT I JUST WANNA PLAY SOME GAMES!!!
edit:  plus temporary screw for extra hold from the plexi to the nasty piece of plywood under it with some black overspray on the sides of it.
bfauska:
whaddayamean finish it later? :dunno  It sounds done to me. ;D  I can't put down my desktop CP long enough to work on my cab, but it's not quite that kind of mess, I suppose I'm doing OK then.  It just takes a balance of playing often enough to remember why your building and building often enough to keep from giving up.
Pages: << < (2/2)
Go to full version
