Main > Main Forum
Visual Pinball Aspect Ratio and Rotation
mark shaker:
--- Quote from: RandyT on April 04, 2007, 11:28:22 am ---
I did some playing around with this after reading the thread posted above (always dreamed of using a widescreen plasma for the table.) You need a graphics card or utility that can rotate your desktop and every table would need to be tweaked for the aspect ratio.
But it does seem to work fairly well. It'll just take some time to tweak the tables. There's also the issue of where to put the scoreboard without hacking in second monitor support.
RandyT
I think that I'm going to take a conservative approach (for once), and build the pinball controls module for my existing cabinet. If it goes over well, then I'll spend the big bucks on a dedicated video pinball cabinet.
I've got 5 real pins, so it will be intresting to see if my friends warm up to Visual Pinball.
I know that this is the wrong forum, but: If the people intrested in playing the tables in "portrate mode" with the backglass on a separate monitor agree on standards, they could spread the load of reworking the tables.
- Mark
Aurich:
For the rotation part I use iRotate on my vertical cab and it works great, check if out if you haven't already it's free. Works fine with an ArcadeVGA, no idea if it works with all cards.
juggle50:
Aurich,
Do you tweak all of your tables as well.
mark shaker:
--- Quote from: Aurich on April 04, 2007, 05:05:33 pm ---For the rotation part I use iRotate on my vertical cab and it works great, check if out if you haven't already it's free. Works fine with an ArcadeVGA, no idea if it works with all cards.
I've tried rotating by "Pivot Pro", my video card driver settings and iRotate (which is a utility for easily changing the video card driver settings).
When I used all three, Visual Pinball's Video Preferences resolution choices went blank, but the tables still played.
In Pivot Pro:
As soon as the Table loaded, the screen snapped back to landscape mode.
Using my card drivers/iRotate:
Playing full screen, part of the table was cropped. (The thread posted above has a fix to center the table.)
Playing windowed, the window size was fixed, so the entire 4X3 screen fit within the 3X4 display (the PC equivalent of black bars on a widescreen TV).
It can obviously be made to work, with a bunch of tweaking. I was disappointed that the beta version of Visual Pinball 8 didn't include a portrate mode.
- Mark
displacedtexan:
I am interested in playing visual pinball on my cocktail with a vertically oriented monitor as well. Have any of you guys tweaked any tables to perfection yet? How can I go about helping? I can easily host the files if necessary...
What settings did you use for Visual Pinball?
I have messed with irotate a little bit and it seems to be workable with some of the console emulators that I have tried.
