Main > Main Forum
how to tell which side of LED is ground?
Pages: << < (3/3)
Kaytrim:
--- Quote from: blueboy on April 03, 2007, 05:17:31 am ---Utt ohhh...
I did get the ones that are 14v...
It looks as though the LED wiz is for a total of 5v....
I'm assuming they will be dull as hell.....Any workaround?
I see the part about hooking the LEDwiz up to the powersupply but the directions are not more detailed than that.
Thanks,
Blue
The power supply hookup is only for 5v not the 12v that you can also get from the PS.  If you try to connect 12v to the keywiz you will more than likely fry you board.  The 5v hookup is for additional amperage because USB only delivers 500ma.
I would suggest that you put your 12v LEDs on ebay and buy the 6v verities.
TTFN  :cheers:
blueboy:
Ewww....
Will something like this work to power 19 of the lights i already have installed?
http://www.happcontrols.com/powersupplies/80021500.htm
Blue
Kaytrim:
you can get 12v off your PC power supply.  You just won't be able to control them with a LEDWiz.
Kaytrim
blueboy:
--- Quote from: Kaytrim on April 03, 2007, 10:04:29 pm ---you can get 12v off your PC power supply.  You just won't be able to control them with a LEDWiz.
Kaytrim
Well, this is good news, I'm assuming i could daisy chain the common as they are all white leds, and then one hook up to the computer power, can you explain how to hook into the power supply, as well as if i need any resistors to ensure i have my needed 12v and  don't blow them all.
Thanks,
Blue
Led wiz for sale soon 8)
Kaytrim:
--- Quote from: blueboy on April 04, 2007, 05:16:35 am ---
Kaytrim
Thanks,
Blue
With the resistor on board you should not have any worry about blowing them.  You can daisy chain the common and the hot wires to each button LED.  The easiest way to get your power is from a hard drive power cable.  Use a mulit meter to check the outer leads with the inner lead next to it.  this will tell you which is 5v and which is 12v.  You can also purchase a product from whammoed called the powermite.  You can get more info from his site www.nicemite.com.
I also sent you a PM on the LEDWiz. ;D
TTFN :cheers:
Kaytrim
Pages: << < (3/3)
Go to full version
