Front End Support > MaLa Frontend
Need MALA/LEDWiz Plugin Help
<< < (2/2)
edge:
orbian:
(1) In the ledwiz configurator, check your global options tab.  be sure you have the following enabled:
- Light Coins, Light Start Buttons, Light Control Buttons, Light Controllers.
(2) In Mala, go to options... Then click on the plugins tab.  Do you see the LedWiz plugin there?
orbian:
Yeah, I tried all that and still no joy. :( I know the LED's and the LED Wiz controller works because the configurator lights them corrently, it's just when running MALA I don't see any response. I must be missing something... I just can't seem to figure out what it is.
Thanks,
Bob
edge:
are you double clicking on mala.exe? or do you have a shortcut?  what happens when you launch a game? anything light up? speech?
orbian:
Yes I am double clicking the MALA.exe in the install directory. There are no flashes or anything. No speach (not sure I even have that set up). Ga,es and everythign start OK, just no lights.
Thanks,
Bob
loadman:
--- Quote from: orbian on March 29, 2007, 03:53:44 pm ---Yes I am double clicking the MALA.exe in the install directory. There are no flashes or anything. No speach (not sure I even have that set up). Ga,es and everythign start OK, just no lights.
Thanks,
Bob
In your pic your ledwiz.cfg is only 1kb in size. That seems a little small.
Can you have a look a that?
Navigation
[0] Message Index
[*] Previous page
Go to full version
