Main > Main Forum
Happ Trackball problem
RacerX:
Well, I finally had time to take the trackball apart and see what's going on. Basically the bearings just needed to be lubed. If the bearings are not rolling as freely as they should, the trackball will "jump" out of it's seat between the 3 rollers just a bit when you roll it to the right (I had it backwards in my original post).
